Bypass module - Broken pats
Old 01-31-2014, 07:27 PM
aford89
aford89's Avatar
Default Bypass module - Broken pats
So long story short the copper ring around my ignition cylinder to read the pats system broke and i am now trying to figure out how to disable or bypass the pats system. will a remote start bypass module work for regulary starting the car if i do not use the remote start portion?
aford89 is offline
Old 01-31-2014, 10:15 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
No, you need to (a) get PATS disabled in the tune, or (b) replace the damaged antenna--option (b) is probably the easiest of the two, any PATS "C" antenna from a junkyard will work. Plan (a) will require removing the PCM and sending it to someone that can disable the PATS, or find someone to come to your house and do the same.
Curious, how did it get "broke"?
cliffyk is offline
Old 01-31-2014, 11:43 PM
aford89
aford89's Avatar
Was trying to be a smart as* and wrap it around the key and use regular ones. So if I get the copper ring from the Junkyard any programming need to be done? Or just plug in and go?
aford89 is offline
Old 02-16-2014, 07:40 PM
aford89
aford89's Avatar
Ok so still have the broken antenna but i sent my PCM to sniper tuning to have the PATS disabled. i recieved my computer back and the car still starts and runs for about 10 seconds and then shuts back off agian. Any ideas? did my Pats not get disabled?
aford89 is offline
lincolnshibuya
10-06-2015 08:45 AM
ChampInSD
10-02-2015 04:55 AM
09-25-2015 06:58 PM
ThatJuanStang
09-25-2015 08:01 AM
03blackwidow
09-20-2015 02:36 PM
Quick Reply: Bypass module - Broken pats
