What tire should i run?
Old 03-03-2014, 05:07 PM
Silver-bullet99
Silver-bullet99's Avatar
Default What tire should i run?
Okay so i plan to run 18x10+25mm XXR 521 gloss black wheels all around on my 1999 gt but i have no idea what tires to run help me out!
Here's a link of the rims
http://www.nlmotoring.com/XXR-521-Wh.../52180142n.htm
Silver-bullet99 is offline
Old 03-03-2014, 07:04 PM
wmfateam
wmfateam's Avatar
What are your plans with the car? Drag, cruise, autocross, road course or street driving? Do you have aftermarket front control arms? Just asking because I am running 18x9.5 and I rub on the front control arm and fender well.
wmfateam is offline
Old 03-04-2014, 12:14 PM
crash
BrandofPoop
crash's Avatar
Originally Posted by Silver-bullet99
Okay so i plan to run 18x10+25mm XXR 521 gloss black wheels all around on my 1999 gt but i have no idea what tires to run help me out! Here's a link of the rims http://www.nlmotoring.com/XXR-521-Wh.../52180142n.htm
You mean these wheels?
crash is offline
Old 03-04-2014, 04:50 PM
Silver-bullet99
Well my plans for the stang is to set it up for the drag strip but still as my daily driver and i dont have any aftermarket control arms..what should i change to make em fit if they do rub?
Old 03-04-2014, 04:51 PM
Silver-bullet99
Yes crash those are them!, are you running 18x10 all around? If yes with any rubbing problems?
Im also dropped 2 inches front and back...
Old 03-04-2014, 07:49 PM
LilRoush
LilRoush's Avatar
18x10 is pretty big on an SN95 unless you're getting into auto x. It's def not a set up for a drag oriented car. I'd go 18x9 fronts with a 265/35/18. It will give a solid side wall with no stretch or buldge (with most brands). Proper offset will not give you any rubbing issues.
On an 18x10, your going to rub like mad when you try to turn unless you have some serious aftermarket suspension going on up front, or have them so spaced out you need fender flares to keep them from spraying your car with road debris.
LilRoush is offline
Old 03-04-2014, 11:16 PM
Silver-bullet99
Dang hate to hear that-.- would i be able to atleast run the 18x10's in the back?
Old 03-05-2014, 12:55 AM
crash
BrandofPoop
crash's Avatar
Yes crash those are them!, are you running 18x10 all around? If yes with any rubbing problems? Im also dropped 2 inches front and back...
I'm not running 18x10's all around and honestly, I wish I had. I have 18x8.5 in the front and they aren't wide enough. I'll have to find a spacer to push it out just slightly. My rear tires are bfg kdw 2's with 295/35/18 and 235/40/18 in the front. I'm lowered 2 inches and have a cobra irs out back.
Attached Thumbnails What tire should i run?-image-1730003586.jpg   What tire should i run?-image-2157114591.jpg   What tire should i run?-image-1155871965.jpg   What tire should i run?-image-2896745648.jpg
crash is offline
musnicki
09-23-2015 07:11 AM
Pyrate Dave
09-10-2015 07:30 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: What tire should i run?
