3.73 gears
Old 03-06-2014, 07:17 AM
zachary1988
zachary1988's Avatar
Default 3.73 gears
I am new Mustang owner. I have a 04 GT with manual transmission. I would like to change out the gear to a 3.73. I did a search on the forum and it shows I have a 8.8 rear end. It was suggested that I would need one of those handheld tuner, like a Diablo(?) to set it up. What would I need completely to have this done? Thanks in advance, Ed.
zachary1988 is offline
Old 03-06-2014, 04:58 PM
sv650lex
sv650lex's Avatar
You will need the gears and I would recommend an install kit with bearings. With a handheld tuner you can recalibrate for the gears so your speedo and odometer isn't off.
sv650lex is offline
Old 03-06-2014, 08:59 PM
Soldier GT
Soldier GT's Avatar
Good luck!
Soldier GT is offline
Old 03-06-2014, 09:31 PM
GTgeezer
GTgeezer's Avatar
I have a 01 with manual and 3.73. very nice package, fun to drive. they were in the car when I bought it so sorry no tips. if your not familiar with gear install I suggest a pro.
GTgeezer is offline
Old 03-07-2014, 06:50 AM
zachary1988
Thanks for the replies. I should have stated that I am not installing them and a mechanic I use suggested that I need to get a tuner. So I will get the gears and install kit with bearings.
Old 03-07-2014, 03:10 PM
hpwrestler220
hpwrestler220's Avatar
You might need new seals too but your mechanic can get them. Definitely ring and pinion and the bearing kit as well.. get the correct gear oil as well...
I went with 3.73 in my manual and although its a lot of fun, im still wondering what 4.10 would have felt like. Or even 3.90
hpwrestler220 is offline
Old 03-07-2014, 06:29 PM
Gt04
Gt04's Avatar
On An N/a Or Centri Blown Motor Run 4.10 Or 4.30s So You're Not Disappointed. 3.73S Or 3.55S For Twin Screws.
Gt04 is offline
Old 03-07-2014, 11:27 PM
SyNdicateZ
SyNdicateZ's Avatar
New bearings and install kit.
Also make sure u get the Ford Racing brand 3.73.......or get the 4.10's.
Also, I recommend a ford racing aluminum driveshaft..
SyNdicateZ is offline
Old 03-07-2014, 11:29 PM
SyNdicateZ
SyNdicateZ's Avatar
I have 4.10's. I would have kicked myself if I did end up getting the 3.73's...
Old 03-08-2014, 02:11 AM
crash
BrandofPoop
crash's Avatar
Having both 3.73's and 4.10's now, I feel that I have more fun with the 4.10's. 5th gear is usable to pass while on the freeway and the car doesn't seem to fall flat after 90 or so. But as of now, my track times slipped 3 tenths with the 4.10's compared to my 3.73's. But that may be due to a need for some new tires.
crash is offline
Quick Reply: 3.73 gears
