SN95 strut tower measurements?
Does anyone have underhood body measurements for sn95s or could go out to their non wrecked car to take a measurement for me. There is a hole in front of the strut mounts or caster camber plates that if you could measure for the center to the center of each of those holes.
Basically I had wrecked the car got it airborne. Swapped some front suspension out, new struts and j&m caster camber plates also. So I go to align it and everything was money but the camber. With the plates all the way to the most positive camber position it still only got to -2 degrees camber on both sides. Car drives straight and nice and I double checked the caster camber plates where right side to side and they are.
I've had to pull the strut towers out on s197s that have been curbed or jumped, so I'm thinking my 2000 gt the strut towers might have been tweaked as I have no strut tower brace (if that would have helped at all at the time of the wreck).
So if anyone has any measurements for me that would be great to see if I need to pull it.
Also how much are my front tires going to be ate up if I drive it with this much negative camber, 2 degrees neg.
Thanks!
Thanks!
09-16-2015 07:53 PM
