Wheelspin light
To replace the abs ring it requires the removal of the axle shaft it is mounted to, which gets more involved. Depending on your skill level, it really isn't too difficult. I had a bent axle shaft, took that shaft out. New shaft didn't come with an abs ring so I pressed it off the old shaft and pressed it on the new shaft.
Would also be a good time to check the axle shaft bearings and seals. This is probably the seal your mechanic was referring to leaking.
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
