HP Est.?
If you're looking for any serious power, FI is definitely your best route. Even on my 3V I'd be lucky to pull 350 RWHP with full bolt ons and full exhaust. Of course, every little thing helps some at least, so don't be discouraged, but nothing helps like boost.
I almost feel like starting over and just dropping a crate Coyote down in it. Good grief. This is my first New Edge, and my first Mustang in 18 years. (First two were Fox bodies back in early 90's.)
Definitely disappointing to hear this. I'm going have to reconsider what my expectations are for this lil project. My first inclination now is throw a 100 shot on it and call it a day. I've read they can handle 75-100 fairly reliably on stock internals. Is this accurate?
If you're looking to do a centrifugal charger so the power is always available, numerous posts exist of guys building kits for roughly $1,500-$2,000. Your 3.73's should pair better with this than a KB.
I'm assuming this car has low miles as well.
Yes, for the price a 100 shot is the best way to go for HP.
3.55's are a better gear since the on-demand power the KB provides, 3.73's will produce wheel spin and the centrifugal pairs better with 3.73's.
You can run 3.73's with a KB yes, but you're going to have spin city.
Not to mention you'll pay less for a centrifugal and be able to use his current set-up with great results.
Your rwhp will vary with your altitude quite a bit. Using some black voodoo math and some sophisticated guessing, I came up with 280 at the crank - at sea level - based on my trap speed and I have most of the bolt on's out there. CAI through the intake is all done, exhaust, tune, and 3.73 gears - so similar setup. I think a corrected number around 250 is reasonable. If it is a hot day out you may see some low numbers, so be prepared for some disappointment.
I feel your pain on the hp/$, I think forced induction on a 2V is the way to go to get decent power.
A Coyote swap has definitely entered my mind a time or two. That would be a head turning build.
