GRR. Help me! Car is Richer than I am
I have an 03 mustang gt 4.6 sohc. I had a supercharged on it when I bought it, then I blew a headgasket and took it off. Since then the car has been running super rich. It throws an 02 sensor code at me, I replaced it. it will throw both banks rich and sometimes one as lean. I have cleaned the MAF and the readings from it appear normal, same as the TPS and fuel pressure. I just ummm "made the cat flow a little better on one side." I ran the short term fuel trim and one bank has a short term of 25% and the other has one of -25%. Could this be because both cats were clogged and now one is flowing way better than the other? or is it a vacuum leak or something else screwed up somewhere? I'm lost and sick of throwing money at this thing.
Anybody out there?
I hollowed out the other cat today. welded it back up. now the short term fuel trim is reading 25% on both banks. The long term fuel trim tends to stay at 0% or fluctuate slightly as it should. Factory tune is back on car. HELPPPPPP MEEEE. What am I doing wrong? the stft doesn't change at 2500 so I'm guessing it's not a vacuum leak. Fuel pressure at the regulator is 39 psi at idle. Obviously not a plugged cat anymore. My wide band o2 reads below 11.0:1 but that may be compromised. I drove the car about 20 miles hoping it would clean off the o2's it didn't help anything. HELPPPP. Any thoughts? At this point my thoughts are selling the damn thing as is and taking a huge hit.
First, what is still on the car that is not factory stock? Make a list and check it twice. My guess would be that the supercharger kit includes higher flow injectors. If those haven't been returned to stock, and you removed the supercharger and put the stock tune back on the car, it's no wonder you have problems.
Sent from my XT1080 using IB AutoGroup
no more boost
The supercharger is not back on the car. Since I have hollowed the cats the short term fuel trim has gone from saying the car is way too rich (beyond the cars capability to bring it back) to saying the car is running way too lean. my wideband o2 says it is still too rich, but I'm doubting that it is reading correctly. the car drives around town pretty good but the second I go to actually get into it, it falls on its face. I can't tell if it is starving for fuel or what.
Your condescending reply is not very well appreciated. I know what you're talking about. I bought the car with the supercharger on it. The fuel system as far as I know is stock, the only item that might not be might be the injectors, the MAF is stock. If the injectors were in fact upgraded the car would be sending a rich code which it was, but since I replaced the cats the car is saying it is too lean. I understand the basic concepts of fuel trim and what might cause this, but I have exhausted most of the options that I know of and am trying to pick other people's brains on the matter.
Your problem is most likely the upgraded injectors, no way the supercharger would run on #21 or #19 injectors whichever your car originally had. Are the injectors pink or orange topped?
I would think your best bet is to install a factory set of injectors and the factory tune. If the supercharger tune is still in the ecm, which sound like it is, then the car will run horrible. And im willing to bet those injectors are 36# or bigger, which will cause the car to fall on its face too.
Massive amounts of unburned fuel can also damage the O2 sensors, which may explain why your fuel trims are swapping randomly.
Next your cylinder walls will be damaged from fuel washing the oil away faster than the engine can supply it. If you keep driving, your bearings will be destroyed next as fuel washes past the rings and dilutes the engine oil.
So, I wasn't being condescending when I was telling you to take it to a real mechanic. If you keep messing around with things you don't understand, you WILL destroy the motor. But it's your money.....
On a 2003, your stock injectors will be pink tops- 21lb. If this is not what you have on the car, STOP driving it until you get stock flow injectors back on it.
