4.6 swap to a 5.0 coyote?
Old 07-06-2014, 04:53 PM
Lilgohlke
Lilgohlke's Avatar
Default 4.6 swap to a 5.0 coyote?
I'm new to the forums, but I was curious if I could do a complete engine swap. I was really wanting to take the 4.6 out and drop a crate 5.0 motor in it. I'm not sure if its possible. What do yall think?
Lilgohlke is offline
Old 07-06-2014, 05:55 PM
Soldier GT
Soldier GT's Avatar
Welcome to the forums...
Soldier GT is offline
Old 07-06-2014, 06:23 PM
samiamthemustangman
samiamthemustangman's Avatar
It can be done. you have to use a tubular k member and leave the k member unbolted while installing the engine. Search for the conversion and some where popular will explain it all.
samiamthemustangman is offline
Old 07-07-2014, 06:42 AM
uberstang1
Chupacabra
uberstang1's Avatar
Easy swap and all the parts are easily available
uberstang1 is offline
Old 07-07-2014, 09:31 AM
Z28KLR
Z28KLR's Avatar
Unless you got a hookup on the engine, trans, pcm and harness, be prepared to spend $12-15K. If you're thinking about f/I as well, you'll push up near the $20K mark. And that's just parts.
Coyote's are f'n sweet engines, but there are significantly less expensive ways to get 420fwhp under your hood. Otherwise, like mentioned above it's completely do-able, everything you need for the project already exists.
Z28KLR is offline
Old 07-07-2014, 11:40 AM
Lilgohlke
Lilgohlke's Avatar
Would y'all recommend camming mine out and maybe putting a pro charger on it? That sounds like it would be cheaper than doing a whole engine swap to me. But I don't know if my motor having 115xxx miles on it will affect anything
Old 07-13-2014, 11:44 PM
Z28KLR
Z28KLR's Avatar
Assuming a healthy engine (good compression etc), I wouldn't stress putting a blower on it at 115K. Keep boost at not more than 10psi, with everything else set up properly and a conservative tune it should be fine.
Z28KLR is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
Quick Reply: 4.6 swap to a 5.0 coyote?
