Rear End Whining while driving.
Old 12-14-2014, 09:40 PM
TheNimbleStang
TheNimbleStang's Avatar
Exclamation Rear End Whining while driving.
So I have a 2000 Mustang GT with many bolt ons, including 4.10 gears on the rear end. Now every time I accelerate and let off the gas, I can hear a loud whine coming from the back of the car. I am suspecting that the bearings are worn out but I'm not really sure. Can anyone help me if there is a problem or it's just me complaining?
TheNimbleStang is offline
Old 12-14-2014, 11:17 PM
ticopowell
ticopowell's Avatar
How long ago did you get the 4.10's installed? It could also be bearings but I would guess that it is the gears first... unless they have been there for a long time and for sure aren't misaligned.
ticopowell is offline
Old 12-15-2014, 06:57 AM
TheNimbleStang
I am not too sure on when the gears have been installed. I bought the car about 2 years ago and the previous owner bought them and had it installed before. I personally think that they are like 5+ years old since other bolt ons on the car seem a bit old. I don't really know for sure, I'm just guessing.
Old 12-15-2014, 01:04 PM
uberstang1
Chupacabra
uberstang1's Avatar
Id start by popping the cover and looks for obviously problems, metal shavings, ring gear bolts backing out, etc
uberstang1 is offline
Old 12-15-2014, 08:22 PM
TheNimbleStang
It's sitting in the garage this winter and wont be moving until next spring. But I will for sure will check it out. I just don't want to work on something that is not causing the problem and waste money. I just hope it is not something gone bad, I really hope it is the bearings since it's cheap to replace.
Old 12-17-2014, 07:00 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
a high pitch whine is usually ring/pinion sound. bad bearings will rumble and grind and make a rotational noise. Sound could be from improper install
WhiteFoxGT is offline
Old 02-09-2015, 01:03 AM
caseystutz
caseystutz's Avatar
Sounds like bearing need replaced and/or the ring you will need to pull them out and look at them
caseystutz is offline
mtgldr
02-03-2024 09:00 PM
mmarsh3014
Wheels & Tires
10-20-2015 09:08 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Dragonus18
09-09-2015 01:21 AM
09-08-2015 11:50 AM
Quick Reply: Rear End Whining while driving.
