What do you guys think? MHS Stage 1 heads...
Hey guys got some bad news from the guys installing my new block (MMR 900). Not only is my teksid trashed but so are the heads. I guess sometimes bad news can be good news. I was all set on buying stock heads and buying another set of HP292 cams but have since decided to buy the MHS Stage 1 heads with Stage 2 blower cams. I was kind of leary about MHS because in the past their customer service sucked. I called today and talked to Jordan and all I can say is wow what a difference! We went over my mod list and he said with what I have now paired with the MHS heads and cams I should be easily over 500 rwhp. Here is my Mod list:
MMR 900 shortblock
Edelbrock vic jr intake/6061 plenum
Anderson Powerpipe
Vortech V1 T-Trim S/C/3.33 pulley
Accufab 75 MM TB
Flowtech LT's/Modified O/R H-pipe Flowmaster American Thunder exhuast
Aeromotive 325 LPH pump/KB 40 amp BAP
MMR high flow fuel rails
Ford racing 410 gears
cx racing intercooler
Wht do you guys think? 500 +? Also I have a 2.87 pulley that I wanted to install but Jordan informed that I will start to have maior belt slippage. Any ideas?
MMR 900 shortblock
Anderson Powerpipe
Accufab 75 MM TB
My man you don't know how close I came to scrapping her. 3 blocks in 2 yrs....Between my deployments and issues that I had with this da** car I've only driven her about 200 miles in the last two years. I tried to cut corners, buy all used parts, get the install at the lowest bidder even went to the lowest cost dyno. Not this time. All new parts and getting her dynoed at the best dyno shop in the central mid west.
