Stock scoop
Old 04-01-2015, 09:48 PM
pei875
pei875's Avatar
Default Stock scoop
Has anyone ever made the stock hood scoop functional? I was thinking of cutting the good and drilling out the honeycomb. What y'all think?
pei875 is offline
Old 04-02-2015, 03:42 PM
AMWill
Former Sponsor
AMWill's Avatar
Hey Pei,
I personally, would not recommend it.
Making the scoop functional, creates a much greater chance of the scoop actually flying straight off of the car and either wasting the hood, or even causing an accident!
When you allow air to enter, but have no-where for it to escape, you are actually generating lift-off.
I would look into aftermarket hoods with functional vents like the Heat Extractor Style Hood.
Hope this helps and let me know if you have any questions!
-Will
AMWill is offline
Old 04-02-2015, 08:05 PM
school boy
school boy's Avatar
Pretty much what AMWill said. I seen people do it, but I also seen a couple rip off of the hood. Look at the Mach 1 hoods and scoop if you want something functional. Its a little bit of modification to get it to work on a 2v engine but is doable.
school boy is offline
Old 04-02-2015, 08:19 PM
cleangraystang
cleangraystang's Avatar
There right I would not even try it. If that's what you want than you should buy the Head Extractor Hood. On my 09 GT I just wanted a better looking hood scoop so I put a 2013 Roush scoop on my GT and I think it looks good but its only for the looks....
cleangraystang is offline
Old 04-03-2015, 09:17 AM
AMWill
Former Sponsor
AMWill's Avatar
You definitely have the right idea school!
We do carry the CDC Shaker System and it is an awesome setup, but it does come with a price tag and some work to install, regardless I would recommend checking it out!
If anyone needs anything, feel free tor each out.
-Will
AMWill is offline
Old 05-08-2015, 12:24 PM
WhiteFaleen2001
WhiteFaleen2001's Avatar
What am I missing here? He said he would drill the honeycomb and cut the hood....wouldn't the air "escape" into the engine bay? My brother did this to his Bullitt and he has had no issue.
WhiteFaleen2001 is offline
Old 05-08-2015, 03:54 PM
kast1376
kast1376's Avatar
This has been talked about many times here and in a bunch of other groups.
The general consensus is it is not worth doing. You have to enforce the scoop to prevent being blown off, and it allows a lot of dirt (and more importantly water) into your bay, which can create a lot of problems. You won't see any performance gains as it is not ducted to your intake and whatnot.
kast1376 is offline
Old 05-08-2015, 04:30 PM
oxfordgt
oxfordgt's Avatar
I did it and it was great. My fuel rails used to get hot and vapor lock. I cut the hood and drilled the honeycomb and no more problems. Probably no real benefit to it on a mostly stock engine.
One downfall was water and dirt would get on the intake.
oxfordgt is offline
Gene K
10-21-2015 11:37 PM
mungodrums
09-29-2015 09:18 PM
ccdguy
09-19-2015 05:20 PM
dunebuggydude11
09-13-2015 03:03 PM
GentleBen
09-11-2015 05:34 AM
Quick Reply: Stock scoop
