lowering
Old 04-21-2015, 07:18 PM
  #21
zachary1988
zachary1988's Avatar
Originally Posted by Z28KLR
^ I also installed a Baer bumpsteer kit and poly offset steering rack bushings, both to help correct steering geometry. Some people aren't fans of offset rack bushings, I guess because under hard use like if you a/x your car they can shift but for normal driving they are fine. Mine haven't moved a bit in over 7 years now.
Get those parts + alignment after install and you'll be good. Again, this is also a good opportunity to get rid of the stock LCA's. You'll also want new shocks and struts, as the stock ones will be a little bit overcompressed and as a result ride quality will suffer a little. Still haven't done mine yet but it's coming soon along with a couple other things that are way overdue.
I appreciate all of your input. What are LCA's? Thanks, Ed,
zachary1988 is offline
Old 04-21-2015, 07:29 PM
  #22
Soldier GT
Soldier GT's Avatar
Hey my man LCA's are Lower Control Arms. They reduce wheel hop and help in traction.
Soldier GT is offline
Old 04-21-2015, 08:25 PM
  #23
zachary1988
Okay thanks. Lots of help here! Ed.
Old 04-22-2015, 12:40 AM
  #24
Gt04
Gt04's Avatar
eibach sportlines or h&r super sports. I run super sports with camber plates and bumpsteer
Gt04 is offline
Old 05-01-2015, 02:24 PM
  #25
zachary1988
Would you recommend taking out the spring isolators? And if so, would you need to replace the isolators with anything else? Thanks, Ed.
Old 05-03-2015, 07:37 PM
  #26
zachary1988
Not really the greatest pics but should give you an idea...
If you drop like this, be prepared for the challenges of driving a lowered car such as scraping the midpipe on
speed bumps (gotta hit them at an angle), scraping the front end on steep driveway entrances (even ones that don't seem all that steep) and hitting the bottom of the front bumper on parking blocks or walkway curbs when you head too far into a parking spot. Definitely a learning curve here.
Would you recommend removing the spring isolators and if so, what would you replace them with?
lincolnshibuya
07-05-2020 03:05 AM
baddog671
07-26-2016 01:20 PM
UrS4
10-03-2015 06:23 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
NYstang
09-30-2015 09:56 PM
Quick Reply: lowering
