I had my 04 Mustang GT lowered using Eibach pro kit springs. It lowered it about one inch. It looks like I still have about two inches in between the tires and fender. What do people do to lower their cars to have about an inch or less in between the top of the tires and fenders? Thanks in advance, Ed.
You could just go with the sport kit from Eibach. Its cheaper than coil overs and lowers about 2 inches. Anything lower and you will might start to regret it.
Yeah school boy hit the nail on the head. Op you should have did a little more research. If you want that lowered look should've went with the sport kit.
Are you talking about the "PRO-SYSTEM Performance Springs and Shocks"?
No, they are talking about the Eibach Sportline springs. They give a 2" drop. You'll need a few additional items to make it work though; at a minimum C/C plates and bumpsteer kit. When I did mine I also installed offset steering rack bushings, poly spring iso's and MM lower control arms out back (good opportunity to do so since it will all be apart). I'll see if I have any decent pics and post one up.
