2002 gt, quarter window, replacement, convertible
Any advice on how to install the driver side quarter window on a 2002 BY convertible? It cam loose from the track so I pulled it out. Took trim off of the areas around the window but only see hydraulics for the roof. How do I access the area for the window? Thanks
Foghorn Leghorn
Location: I reside in a near constant state of amazment.
When you take off the interior panel and the rear speaker assembly, you'll see what you need to see. I used some gasket sealer to secure the glass to the metal part and put it all back together.
I wound up having to do it to both rear windows when they both let go about the same time and it has held up just fine for several years now.
Kristopher Gangwer
12-06-2015 02:56 AM
