I unintentionally slammed my stang...
Old 05-16-2016, 06:01 PM
Drastang
Drastang's Avatar
is the wear on inside on both?
Drastang is offline
Old 05-16-2016, 06:03 PM
EpicMoses
EpicMoses's Avatar
Yeah it is. I brought my car to a shop and they said they'll take a look at it in the morning so hopefully they can fix it or tell me what is wrong.
EpicMoses is offline
Old 05-19-2016, 06:38 PM
EpicMoses
EpicMoses's Avatar
Ok I just found out what the problem is and will post the pics once I get home or the nearest gas station. Don't wanna explain cause I don't remember all the specific words he used.
Old 05-19-2016, 07:22 PM
EpicMoses
EpicMoses's Avatar
*I suck at part names so excuse my ignorance
You can see that the driver side axle is leaking fluid and is not sealed like the passenger side. These guys at the brake shop told me that the thing in the axle tube is bent or and is causing the wheel to have negative camber.
So I can either:
A. Buy a new axle for $600
B. Buy a used axle for less
C. Buy the parts for the DS axle and pay for the manual labor
Old 05-19-2016, 08:10 PM
dawson1112
dawson1112's Avatar
Contact local yards and see if you can buy a used one, that's what most shops will go with any ways. There are millions of used 8.8 rear ends out there.
Id say the previous owner jumped a curb or something with it.
dawson1112 is offline
Old 05-19-2016, 08:12 PM
EpicMoses
EpicMoses's Avatar
Would there be any parts I would have to replace on the used one? Just off the top of your head I'll ask a mechanic anyways.
Old 05-19-2016, 08:29 PM
dawson1112
dawson1112's Avatar
If you just find a used one out of the junk yard 99-04 GT then it will just bolt right in. You could look and see if you can find just the housing, then all youd have to do is swap the axles and rear carrier into it. Your problem is the axle tube took a hard hit and was pushed up and out of alignment from the pumpkin. You may even be able to find a machine shop that can straighten it out and weld it.
Old 05-19-2016, 08:32 PM
EpicMoses
EpicMoses's Avatar
Ok I'll look around but people down here don't seem to like working on suspension parts.
Goldenpony
03-26-2016 06:41 PM
Taiwan Cameron
03-25-2016 06:59 AM
mustangman02232
03-13-2016 01:28 PM
millhouse961
03-04-2016 06:09 PM
buttonz75
02-26-2016 10:21 PM
Quick Reply: I unintentionally slammed my stang...
