what do you use to pump trans fluid into trans?
Old 07-02-2016, 01:55 PM
99GTvert
is my username.
99GTvert's Avatar
Default what do you use to pump trans fluid into trans?
I've taken off the shifter and filled the transmission a few times before but this time I want to try and just pump the fluid into the fill hole because I don't feel like messing around with the old gasket crap and removing extra screws/bolts etc.
Do you guys use a generic pump that attaches to the top of a quart bottle, or have any other particular device to help with filling the transmission? Will not be using a lift so just jack stands.
99GTvert is offline
Old 07-02-2016, 03:02 PM
09GT/CS
09GT/CS's Avatar
The plastic fluid pumps will handle about four quarts after that they start to come apart it's a tad thick for them to handle. I found one at harbor freight a while back and it had a metal case and has held up well. I even use it on the diff with the super thick gear oil. I'll see if I can find a link for you.
09GT/CS is offline
Old 07-02-2016, 10:15 PM
Simon1
Simon1's Avatar
When I do mine I just connect the lines coming from the transmission to my cooler and start the engine and then let it pump old fluid out and then I hook up my little hand-held pump to individual quarts and pump it back in.
It's a gigantic pain in the ***. I'm considering getting a different dipstick with a larger hole an electric pump so I have to do it all over again.
Simon1 is offline
Old 07-02-2016, 10:31 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
I'd like to see the TS use his cooler lines on a manual trans lol
WhiteFoxGT is offline
Old 07-10-2016, 06:09 AM
chipss36
chipss36's Avatar
done it both ways, in through the shifter is about as easy as it gets, with the least mess...
imo
chipss36 is offline
Old 09-08-2016, 04:48 PM
uberstang1
Chupacabra
uberstang1's Avatar
I use a pump from harbor freight, looks like a giant black syringe with a hose on the end, stick it in , pull out the lever, stick it in, push the lever, done. Keep minds out of the gutters.
uberstang1 is offline
Paul Deasy
06-10-2016 01:51 PM
rocky321
06-03-2016 01:45 PM
Bradley's GTCS
05-26-2016 10:31 AM
flash_xx
05-25-2016 10:27 AM
08hybridok
04-29-2016 10:09 PM
Quick Reply: what do you use to pump trans fluid into trans?
