I'm having this gauge installed by a local shop. They had my car all day and they still aren't done with it. Does anyone else have this gauge? Is it really that time consuming? I had them install my boost gauge and did such a good job I took it back to have them install this one. The air/fuel gauge must have more to wire up.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
Well if your boost gauge is mechanical then there shouldn't be anything to wire up except the light.
The air/fuel ratio gauges are wired to an O2 sensor before the cats. It shouldn't take all day IMO, i bet they ran longer than expect on other jobs and didn't get to it today.
__________________
Boost or Buell, decisions, decisions.
whipple HO SC,FRPP springs, Pypes mid mufflers, hurst, 4.10's, J&M extreme joint lca's, adj. UCA, relo bracets, 1 piece DS, spec stg 2 clutch. Accel coils 12.52@117.6mph so far with a 2.01 60 ft time(pre shaft, coils, clutch).
Doesn't the sensor, that comes with these air/fuel gauges, replace the stock O2 sensor before the cats? I assumed that is the way it works or do you actually have to weld something to the exhaust manifold to install it?
Quote:
ORIGINAL: Wally39
It has it's own Bosch sensor.
Wideband
__________________
The wide bands get there own sensor. It'll take a muffler shop about 2 minutes to weld in an o2 bung and shouldn't take more then an hour to do the wiring. They must be backed up. Hopfully.
The wid band sensors compared to a regular A/F gauge are just really more accurate. A normal A/F gauge will still do it's function but with a wideband you can get the actuall reading, i.e. 11.4.
I got a regular A/F gauge in a nitrous car and it did it's job when an injector went out. Pegged lean so we let off. The $60 gauge saved the motor.
