Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-02-2008, 05:06 PM   #1
SirKnightTG
2006 Ford Mustang
SirKnightTG's Avatar
Vehicle: 2006 Mustang GT Premium Auto - Vista Blue
Default Comp Cams 3V Thumpr NSR
Comp Cams 3V Thumpr cams. NSR but need phaser limiters.
These sound pretty close to the FRPP Hot Rods. I don't know the power gains from these. I also wonder how hard is it to install the phaser limiters. At least they're NSR.
If these end up making significantly more HP than Hot Rods, I may have to reconsider.
I found this link on Sutton HP's site and these will be available on 08/15/08.
EDIT: Whoops. It's Thumpr, not Thumper.
__________________
Boomtube crew
TCI StreetFighter crew
Kooks crew
FRPP Hot Rod cams coming soon to a Thanksgiving near you...
camthumpinstang is a scammer!
SirKnightTG is online now   Reply With Quote
Old 08-02-2008, 05:31 PM   #2
Dragon Stang
Dragon Stang's Avatar
Vehicle: 2008 GT
Default RE: Comp Cams 3V Thumpr NSR
They do sound nice! Very similar to the FRPP hotrods. Do you have a part number for those comp cams? Would like to check them out. I can't see why they would need phaser limiters though.
__________________
2008 Mustang GT 5-cog Manual
Dark Candy Apple Red
3.55s
Mods: Shorty Antenna
MGW
FRPP Stingers
Dragon Stang is offline   Reply With Quote
Old 08-02-2008, 05:43 PM   #3
SirKnightTG
2006 Ford Mustang
I can't find a part number. Check back on suttonhp.com on the 15th.
Here's comp's reason for phase limiters:
Quote:
What does the COMP Cams® Phaser Limiter Kit do?
These limiter plates replace the factory back-plate on the cam phaser. They have posts which extend into the cam gear’s control chambers, limiting their movement to no more than 20 degrees. This gives more piston to valve clearance and lets you install bigger, more powerful camshafts with safe piston to valve clearances. While keeping up to 20 degrees of movement available, all the wide-open throttle benefits of the cam phasing are retained, since the normal retard the cams see at wide-open throttle is only around 9 degrees.[/b]
I suspect these will be the most powerful NSR cams to date b/c of this.
I very much look forward to seeing specs and dyno runs with these as well as finding out how the install of this limiter is.
__________________
Boomtube crew
Kooks crew
Old 08-02-2008, 06:43 PM   #4
hammeron
hammeron's Avatar
Vehicle: 2006 GT
these comp cams do sound great
i want my stang to sound like that, some day
__________________
2006 GT Supercharged
Whipple Crew
FRPP Hot Rod Cams
M-5230-S (KR's)
hammeron is online now   Reply With Quote
Old 08-03-2008, 02:25 PM   #5
hirevn
hirevn's Avatar
ill be kepping my eye on these for sure.
__________________
"2008 black gt premium"
Paxton HO Blower
Brenspeed paxton tune
SLP power flos
Hurst billet short throw
BMR Lowering kit and LCA'S
Yes, the fast car is still the camaro.
hirevn is offline   Reply With Quote
Old 08-03-2008, 02:34 PM   #6
gman73
gman73's Avatar
Vehicle: 06 Mustang GT
From what I have read from mustang gurus is: Stick with stock cams unless you plan on going F/I otherwise you will probally loose power, especially in the lower ranges. Getting cams for sound is retarded.
__________________
06 Silver Mustang GT
BFG KDW 245/45/17
Steeda UDP
Diablo predator-Bamachips 91 race tune.
JLT intake
FRRP 4.10
Maganpacks
Prochamber w/magnaflow hi-flow cats.
gman73 is offline   Reply With Quote
Old 08-03-2008, 05:23 PM   #7
SirKnightTG
2006 Ford Mustang
Quote:
ORIGINAL: gman73
Ugh...not more of this again...[:'(]
__________________
Boomtube crew
Kooks crew
Old 08-03-2008, 05:44 PM   #8
Dragon Stang
Vehicle: 2008 GT
I found this info on another site. Might want to check it out.
http://www.moddedmustangs.com/forums...w-3v-cams.html
You will have to fill in the **** with "m o dd ed mustangs" (without the spaces) to get the link to work. I'm sure you allknow the site. Apparently,"mustangforums.com" feels mentioning another competing site is going to destroy them. This site has its ownmuch bigger issues like using antiquated forum software for one.
__________________
3.55s
MGW
FRPP Stingers
Old 08-03-2008, 05:57 PM   #9
SirKnightTG
2006 Ford Mustang
Quote:
ORIGINAL: Dragon Stang
I agree. And it's not like most others here do not have accounts at other places. It's not like you have to pay to be a member, it's all free so I don't understand the censoring at all.
In regards to the cams, I'm really hoping this doesn't mean that not using phaser limiters on FRPP Hot Rods is a bad idea since they have the same lope.
__________________
Boomtube crew
Kooks crew
Old 08-03-2008, 06:05 PM   #10
Dragon Stang
Vehicle: 2008 GT
Me too Dude... Me too. Thats another 200 bucks I could do without spending if not needed. I may have to go with the FRPP cams in this case.
__________________
3.55s
MGW
FRPP Stingers
3v, cam, cams, chart, comp, dyno, facts, mustang, nsr, s197, specs, stage, th265ll, thumpr, xfi
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
