Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 01-08-2009, 02:03 PM   #1
shanec
shanec's Avatar
Vehicle: 2008 Mustang GT
Default header install question
I am FINALLY installing my longtubes this weekend!
Two things I want to avoid in order of priority:
1) breaking a header bolt off into the block
2) having the headers come loose
How tight should I tighten the header bolts? Bassani directions don't say. Is there a torque spec? And if there is - I am skeptical that I could fit a torque wrench where the header bolts are.
Help me out here.
shanec is offline   Reply With Quote
Old 01-08-2009, 06:31 PM   #2
abarker8541
abarker8541's Avatar
you need to buy yourself a manual buddy. they will give you the torque specs and what not.
__________________
06 redfire, Foose Nitrous 20", SCT LW, hurst, SLP LM 2s. JLT.
4.10s and Kooks long tubes sittin in the garage
*DRIVES NAKED CREW*
abarker8541 is offline   Reply With Quote
Old 01-08-2009, 07:44 PM   #3
aircare84
2006 Ford Mustang
aircare84's Avatar
There is a torque spec for the manifold bolts, but like you mentioned, it will be quite difficult getting a torque wrench on all the bolts/studs.
It's 25Nm or 18ft/lbs for the V-8.
I tightened mine down & did not use a torque wrench. I've gone back twice & checked for tightness & have not had any loosen up.
__________________
2006 Torch Red GT/Manual
JLT2 CAI w/Brenspeed 93 Tune
CDC Classic Chin Spoiler,MGW Shifter
Moss Tailight bezels w/Rear blackout panel
Vista/MRT Rear Louvers,Magnum Wheels
Black C-Stripes,Sequentials,Shaker
GT-500 Pedals & CS Shifter Bezel
O/R H,GTA's,OBX L/T's
aircare84 is offline   Reply With Quote
Old 01-08-2009, 07:56 PM   #4
shanec
shanec's Avatar
Why didn't I think of that. Right here on page 27 & 28 - http://iihs.net/fsm/?dir=159&viewfile=Engine.pdf
Answer...18 lb-ft for the nuts that go on to the studs. That's half the answer.
The other question is how much to tighten the studs that go into the block (the studs that the aforementioned nuts go on top of). Must not be very tight because those studs only have a 4mm head on them.
I also noticed the cam overs only have 89 lb-inches (not lb-ft) on them. That's not tight at all.
I'm scared to death of over-tightening a stud into the aluminum block. Would be a serious #*$%^ to strip out a header stud hole.
Old 01-08-2009, 07:57 PM   #5
shanec
shanec's Avatar
Thanks for that.
Silly question here - but how tight would you say you got them? "Real tight" as in you really beared down on it? Or just "kinda tight".
Looking for something to go on here.
Old 01-11-2009, 12:25 AM   #6
Srt2Stang725
you could set a torque wrench to 18 ft/lbs and try to tighten something like maybe a wheel nut..that way you could try to judge what 18 lbs feels like and go from there....i dont know if that will give you a good feel for the amount....just an idea i had
__________________
2007 Mustang GT 5-Speed Manual
Srt2Stang725 is offline   Reply With Quote
Old 01-11-2009, 04:29 PM   #7
aircare84
2006 Ford Mustang
aircare84's Avatar
Quote:
Originally Posted by shanec View Post
Thanks for that.
Kinda tight...little more than snug.
__________________
Old 01-12-2009, 10:06 AM   #8
jared188
jared188's Avatar
Vehicle: 2007 Ford Mustang GT
Shane I was wondering because I am going to be putting on my JBA long tubes soon if you are going to change the motor mounts like they recommend? Let me know how the install goes so I have an Idea what I'm in for.
Thanks
jared188 is offline   Reply With Quote
Old 01-12-2009, 10:08 AM   #9
shanec
shanec's Avatar
I did not change the motor mounts, and I never saw that was recommended for these headers.
More info on my install here - http://mustangforums.com/forum/4-6l-...n-day-1-a.html
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
