Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-21-2009, 07:55 AM   #1
gottinelli
Vehicle: 2008 GT California Special
Default Longer shift lever without a short throw?
First post, thanks to all that respond. Basically I'd like to lengthen my shift lever from stock and have only seen longer shift levers as a part of a short throw package. Anyone know of a longer shaft for the stock set-up? I don't really need the short throw setup, just a longer shifter arm. Thanks again....
gottinelli is offline   Reply With Quote
Old 09-21-2009, 08:12 AM   #2
jdmcbride
jdmcbride's Avatar
Vehicle: 2008 Mustang GT
The Steeda Tri-Ax shifter is exactly waht you are looking for. I got that shifter with their Billet Pro Street Shifter Handle and I love it. Taller shifter with a nice throw.
__________________
08 GT Premium, Manual 5 Speed, 3.55s, 18" Polished Bullitts, HIDs, IUP, Premeir Trim, Amb. Lighting
Appearance: HID Fog Lights, Smoked Turn Signals, 14" Antenna, Black Mirror Caps, Black Painted Calipers, Sequentials, GT500 Spoiler
Steeda: UDPs, HD Motor Mounts, Tri-Ax w/Pro Street Shift Handle, Alum Driveshaft, Billet LCAs, Axle-Back Exhaust, CAI w/Carbon Fiber Elbow
Other: JBA Ceramic Shorty Headers, Brenspeed 93 Tune
jdmcbride is offline   Reply With Quote
Old 09-21-2009, 09:09 AM   #3
Goldenpony
Goldenpony's Avatar
Not sure how you can accomplish this without a different shifter. MGW allows for all kinds of adjustment and is the best shifter on the market.
__________________
2006 Premium GT Convertible
Screaming Yellow, Black Top
5 Speed
18" "Fanblade Wheels"
CORSA Performance exhaust
Brenspeed 93 octane tune
MGW Shifter
Goldenpony is offline   Reply With Quote
Old 09-21-2009, 09:22 AM   #4
gottinelli
Thanks to those that have replied. However, I'm just looking for the shifter shaft and not a complete short-throw system as you have suggested. I have looked at the Roush, Hurst, MGW & Streeda, but don't want or need to change the throw, just the shifter lever length....
Old 09-22-2009, 12:04 AM   #5
hardcore302
hardcore302's Avatar
Vehicle: 2007 Ford Mustang GT
the mgw shifter ball by itself on the stock shifter made it taller and it's alot better
__________________
2007 black GT- JLT2 w/ Brenspeed tune, FRPP X, Edelbrock mufflers, GMS strut brace, BMR UCA, LCA's, panhard rod, Summit A-arm brace, baby seat.
hardcore302 is offline   Reply With Quote
Old 09-22-2009, 12:49 AM   #6
squawskier1080
Vehicle: 2005 Mustang GT
check this out, might be similar to what your looking for http://www.americanmuscle.com/steeda...509-black.html
__________________
squawskier.vndv.com
squawskier1080 is offline   Reply With Quote
Old 09-22-2009, 12:03 PM   #7
bigray327
bigray327's Avatar
If you make the height longer, it's going to make the throw longer. If you want to increase the height while keeping the throw the same, you'll need to shorten the throw.
I highly recommend the MGW shifter, which has adjustable throw and height.
__________________
bigray327 is offline   Reply With Quote
Old 09-22-2009, 11:32 PM   #8
07musclemustang
2007 Ford Mustang
07musclemustang's Avatar
Vehicle: 07 Mustang GT Rag Top
correct
if you lengthen the shifter arm the throw WILL increase so the only solution is to get a short throw shifter and then put a ahifter arm on that you like.
i drew a picture for you to help explain.
the fulcrum point is fixed but the length of the lower part of the shifter assembly must be shorter to accomidate a longer shifter arm. your need to make up for the longer shifter arm by decreasing the length of the bottom of the fulcrum point.
I have a pro 5.0 shifter and am thinking of buyin a curved handle to bolt onto the shifter it would be longer but closer and cooler anyways just thinkin
but either get a mgw as it is the easiest to adjust or a pro 5.0 or hurst and bolt on whatever handle you want or make your own
__________________
07 GT Rag Premium, Black on Black
GT 500 Front End, Rear Spoiler Delete,
FRPP Hood Pins, Functional Hood Scoop,
PIAA 510 4300k Fogs, 4300k HID DRL Delete,
Steeda 90mm Intake and Tube, Steeda UDP,
BMR Combo LCA, UMI Poly UCA, BMR FSB Delete,
SCT Xcal 3, FRPP CMDP, Innovate Wide 02
PRO 5.0 Shifter, Custom T and Handle
Pypes Mid Muffs, FRPP X pipe
FRPP 4.10s and True Track
13.2 @ 109 at 2400ft above sea level
12.8 @ 111 DA corrected
07musclemustang is offline   Reply With Quote
Old 09-22-2009, 11:35 PM   #9
07musclemustang
2007 Ford Mustang
__________________
50, california, dealer, gt500, lever, levers, make, mgw, mustang, pro, shift, shifter, short, swap, throw
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
