Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-23-2009, 01:55 AM   #1
poloxaddict
2006 Ford Mustang
Vehicle: 2006 Mustang GT
Exclamation Please help. Ticking noise on 06 GT.
Heyyy.
This is not good please help me outt.
Alrightyy i have a 06 GT and i've done a little work on the engine but i have alot of learing to do when it comes to cars.
My car has been running pretty good put new rims on it about 300miles ago. i opened it up about 4000RPMs an a ticking noise started up i heard it before put the rims on there.
It's pretty fast and not to loud. Sounds like it coming from around the throttlebody. My engine seems to be running way to hot but the thermometer is just at half way. What could this be??? Thank you.
On my stang i have put a steeda air intake, steeda throttle body spacer, catback magnaflow magnapack, SCT tune, 20' 8.5' Zinik rims, michelin a/s tires, speakers an a 12'sub, halo's and taillights.
If you have any idea please help me out.
Thank you very muchh!!!
poloxaddict is offline   Reply With Quote
Old 09-23-2009, 02:44 AM   #2
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Vehicle: 2006 Ford Mustang GT
could be that our 3V motors can and are noisy....the ticking might be lifters which are noisy on our cars....it might just be normal. Any sound file might help....have you had any loss in power....does she run well in general?
__________________
2006 Mustang GT with Cervinis Kit
Whipple Crew member
H.O. S/C 465 RWHP and 440RWTQ
First online article about my car! check it out!
http://www.examiner.com/examiner/x-8811-Detroit-Sports-Car-Examiner~y2009m5d30-Jason-McGuires-2006-Mustang-GT
http://www.cardomain.com/ride/3342086
www.mocsem.com
mygt500 is offline   Reply With Quote
Old 09-23-2009, 05:04 AM   #3
07 GT E UPP
07 GT E UPP's Avatar
Vehicle: 2007 Mustang GT, 5 Speed
Poloxaddict.... Your problem could be noisy Lash Adjusters or Injectors, or...... ??
Sorry, an '06 doesn't have lifters. Check Ford's Technical Service Bulletin TSB 06-4-7 "Ticking Noise from Engine on 4.6 3V ".
__________________
2007 Black/Black GT 5 Speed
Silver Stripes,SCT-XCal2,Borlas,C&L,Kooks LT+Hi Flo Cat-H,94 Dyno Tune,Seq Tail Lites,Pwrhse 1pc Alum DS,Strut Towr Brace,4:10s,Hurst Shift,UDP,Roush Hood Scoop+1/4 Window Louvers,Roush Front Facia+Front & Rear Spoilers,Chrome Cam Covers,Adj UCA/LCA,Eibach Pro,Tokico Struts,CC Plates,HD Strut Mounts,Bumpsteer,PH Bar+Brace,HD Sway Bars+End Links,CMCV,DD Bullitts 9x18 10x18,Nitto 255/45 285/40,FRPP HotRod Cams,FRPP 3 3/4" Tach/Shift Light,FRPP Billet 62mm Throttle Body
07 GT E UPP is offline   Reply With Quote
Old 09-23-2009, 10:07 AM   #4
Nuke
2007 Ford Mustang
My Garage
Nuke's Avatar
Vehicle: 2007 GT
Send a message via AIM to Nuke Send a message via Yahoo to Nuke
+1 on the TSB for possible noisey injectors. Quite a few people post about ticking noises that turn out to be the injectors. A certain amount of that is considered normal. Ford will SUPPOSEDLY determine if it's normal or not (good luck). Our engines heat soak pretty bad and will seem to give off more heat than normal. If you're not showing signs of overheating I wouldn't sweat it.
BTW, trash the TB spacer. The extra weight outweighs the NADA, NONE, ZERO, ZIP performance gains.
__________________
Rick
07 GT Prem: Alloy, MT, 3.55's, Steeda CAI w/Brenspeed tunes, FRPP Stingers, 275/40/18 Goodyear Eagle F1 A/S on SVT Cobras (OE GT500's), 14" shorty, Wheelskin side scoops & qtr window louvers, A-H rear window louvers, SHR honeycomb blackout panel, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
06 V6: Legend Lime, Pony Package, 14" shorty, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
Nuke is offline   Reply With Quote
Old 09-23-2009, 12:45 PM   #5
poloxaddict
2006 Ford Mustang
I'll try to get a sound clip up..
I dont think its a normal sound..
But its only when i open my engine up a little.
Runs normal tho.. i'll check out the TSB
thank you!!!
Old 09-23-2009, 07:45 PM   #6
moosestang
thank you!!!
When you say open up, do you mean at idle or while driving?
__________________
Boost or Buell, decisions, decisions.
whipple HO SC,FRPP springs, Pypes mid mufflers, hurst, 4.10's, J&M extreme joint lca's, adj. UCA, relo bracets, 1 piece DS, spec stg 2 clutch. Accel coils 12.52@117.6mph so far with a 2.01 60 ft time(pre shaft, coils, clutch).
Downshifting Crew Member
moosestang is offline   Reply With Quote
Old 09-24-2009, 05:50 PM   #7
expect212
Vehicle: 08 Mustang gt
maybe nosieyyy injectors
expect212 is offline   Reply With Quote
Old 09-26-2009, 02:55 PM   #8
3v4.6l
if you only hear it when you have the hood open I would think it's the injectors, if you here it when your driving down the road then I would be concerned.
__________________
2006 mustang gt, auto, tungsten grey, c&l intake, xcal2 with brenspeed tune, mac axleback
3v4.6l is offline   Reply With Quote
Old 09-28-2009, 01:14 AM   #9
GT Bob
Vehicle: 2007 GT
The reason your feeling so much heat is because of the Aluminu block and heads. UNlike Iron which keeps the heat in more, the aluminum radiates ALOT more heat. It's normal
__________________
"Vera" '07 GT, 3.55's, MGW Shifter, BBK Shorties, GTA's, Steeda UDP, ProFab CAI #6, Summit Racing COP's,FRPP LCA's, Edlebrock PHB,UCA and STB, Steeda PHB brace, GT500 18x9.5 285/40/18's
Hang up and Drive.
GT Bob is offline   Reply With Quote
Old 09-28-2009, 12:55 PM   #10
4wheelfun
Vehicle: 2005 GT
I had a similar issue on my 05. It was 3 loose spark plugs.
Before the fix I could hear it while driving (re-verb off outside obstacles (walls parked cars, etc...)).
After, no outside noise, just normal injectors noise when the hood is up.
__________________
2005 Mustang GT sleeper. Whipple SC. MGW
Project on going.
2008 Ford Sport Trac. 4.6 V8 / hypertech / Magnaflow on 20's
4wheelfun is offline   Reply With Quote
08, 2005, 2006, 2008, 3v, 46, bad, engine, ford, gt, lifters, loss, mustang, noise, power, rear, tick, ticking
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
