Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-13-2009, 06:32 PM   #1
doctorstrobe
Vehicle: 2006 Mustang GT Premium
Angry Limped home today and SCT won't read codes.
Limp home mode really sucks.
I did the 'drive of shame' this afternoon.
Went out for a drive and didn't get more than a quarter mile and the little wrench showed up and the engine went into 'limp home mode'.
Fortunately I was only a short distance from home down some back roads.
I have no idea what the problem was since my SCT X2 wouldn't read the trouble codes.
It just says 'error reading codes. press sel.'
Also tried another code reader I have, and a Diablosport Predator for my Grand Chrokee SRT8. None could read the codes, just got errors.
Finally tried Clear DTC and it worked and runs fine now.
Anyone else ever have this happen?
No recent mods. Haven't driven it in a week. It's colder weather here now.
It's not stock so could be a whole lot of things...
I tried searching this forum but didn't find anything similar.
Thanks.
__________________
doctorstrobe
Whipple Crew Member
06 GT, Screaming Yellow, Whipple HO Blower, Spohn LCA+UCA, Steeda Panhard bar, Hurst Shifter, Steeda CF Splitter, 4:10 on Auburn LSD. VMP Whipple Tune with IAT Relocation.
doctorstrobe is offline   Reply With Quote
Old 10-13-2009, 07:13 PM   #2
socalwrench
socalwrench's Avatar
Vehicle: 2008 Mustang V8
Without hooking it up to a normal scan tool- there's no way of knowing what the codes were. However, for it to go into limp mode- the computer would have to see something very wrong- like a failed CMP signal or interrupted injector signal.
Probably, one of the sensors went outside it's acceptable range. Now, your reflash is supposed to take care of that, but who knows for sure.
__________________
Greg - Owner/Operator: GRH Performance
socalwrench is offline   Reply With Quote
Old 10-13-2009, 07:52 PM   #3
hammeron
hammeron's Avatar
Vehicle: 2006 GT
the wrench may or may not come back for
quite awhile, but if it does just pull over
and shut the car off. wait a few minutes then
start her up again. unless there is a real
problem, you'll be good to go.
hammeron is offline   Reply With Quote
Old 10-15-2009, 02:27 PM   #4
jgorm
What were you doing when it popped the code? Did you change anything on the car?
__________________
Trick Tuners Forums
jgorm is offline   Reply With Quote
Old 10-15-2009, 10:35 PM   #5
doctorstrobe
Quote:
I was just going out for a drive...
I hadn't driven it in about a week. Haven't changed anything in about a year.
I was pulling out onto a road, was just about to shift into 3rd gear and it just lost all throttle. Engine was still running but sounded like it was on 3 cylinders...
Thanks.
__________________
doctorstrobe
Whipple Crew Member
Old 10-16-2009, 09:22 AM   #6
Lito
try to get an scanner that could read freezed frames.
Lito is online now   Reply With Quote
Old 10-16-2009, 09:37 AM   #7
antonio1988
2008 Ford Mustang
antonio1988's Avatar
Vehicle: 2008 Ford Mustang GT
disconnect the battery for 15 minutes then reconnect and see if it comes back on
__________________
JLT,CMCV Delete, MAC L/T, X-Pipe & Dumped M80s, 3.73s, CHE LCA, Steeda Adj. UCA, Steeda Adj. Panhard Bar, Steeda Camber Kit, TCI 3000 TC
331/336... 8.291@82.4mph in the 1/8th
Built by Ronnie Sanchez of MMP... Tuned by Chris Jones of BBR... What a great team!
antonio1988 is offline   Reply With Quote
Old 10-20-2009, 01:58 PM   #8
07hotwheel
Vehicle: 07, FORD, MUSTANG GT
My V6 would do that when I put in 91 gas, not always, but often enough i went back to 87. I pulled over, shut car off, and it reset. Sucks
07hotwheel is offline   Reply With Quote
Old 10-20-2009, 02:14 PM   #9
onederful100
onederful100's Avatar
Vehicle: 2007 GT 1992 LX 5.0
mine did this over the weekend, no wrench light just the engine light and no limp mode.
my livewire could not read the code, nor could my generic OBDII reader.
i did clear the CEL with the livewire, and it never ran badly, ran like normal.
a week ago i did add 6% fuel @ WOT and brought the a/f down to 11.3 @ WOT, before it was 11.7.
i talked to my friend who tunes my GT, he said if it happens again to bring it in and he'll look at it. but he didn't really have an answer without looking at it.
__________________
Whipple Crew Member
2-Stang Crew Member
my car
onederful100 is offline   Reply With Quote
Old 10-28-2009, 05:53 PM   #10
doctorstrobe
Some more strangeness:
So I'm checking the strategy code with the SCT and I compared it to the records I kept from when I got the tune. They're different now!
I did bring the car to the dealer to have the Air Conditioner fixed and I told them NOT to re-flash the PCM for any reason...
How could this be possible? Could it actually run on a stock tune with the Whipple?
I haven't driven it much since then to be honest...
CORRECTION: The strategy is correct. They didn't re-flash the PCM...
I tried re-flashing and it runs the same as it did. Warms up for a few mins then craps out.
UPDATE:
It helps to read the owner's manual
The wrench icon means there's a problem with the electronic throttle control system.
Did some research. Could be a problem with the trottle position sensor, throttle body actuator, the PCM itself...
Strange that I can't read any codes though...
I'll probably have to bring it to dealer.
__________________
doctorstrobe
Whipple Crew Member
body, code, codes, finding, ford, home, limp, mode, mustang, sct, strategy, sucks, throttle, tuner, updates, x2
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
