Quote:
Originally Posted by MidLifeCrisis06GT
I have been missing third gear upshift when power shifting pretty often. I have the Ford Racing Hurst short shifter. Seems to be an issue only when winding out second...can't get to third sometimes. Any hints on how to fix this. Sucks hitting the rev limiter when I miss the shift.
I have the same shifter and I've missed 3rd about 4 times in the past year, but it's always when I'm being casual, not when I'm "going for it". Maybe double check the install, make sure everything is torqued? did you use loctite?
__________________
Matt, 2008 Mustang GT, Steeda 90mm intake, Saleen CMCV Deletes, Diablo, FRPP X-pipe, FRPP Stingers, Tokico Springs and Struts, GT500 Camber Plates, FRPP Sways, CDC Chin, GT500 Wing, blah blah blah....
