Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-03-2009, 12:11 AM   #1
10GTSTANG
10GTSTANG's Avatar
Vehicle: 10 Ford Mustang
Default Whipple adjustable tensioner clearance?
Whipple Doodes, this adjustable tensioner for the belt seems like a problem waiting to happen. If it slips the belt will rub together. Is this much of an occurance? At least on my setup with the 3.25 pully on the blower and the 100mm pully on the driver's side, there is not that much clearance.
__________________
Whipple HO, Kooks Long Tubes, Kooks Catted H Pipe, Magnaflow Magnapacs
502 HP where the rubber meets the screet
497 ft/lbs where the rubber meets the screet
USN Retired
10GTSTANG is offline   Reply With Quote
Old 11-03-2009, 01:47 AM   #2
nineinchnail1024
Vehicle: 2006 Mustang GT
You're talking about the upper sliding tension pulley mounted on the alternator bracket, right? Mine has only been tightened once (when I installed the whipple) and has never moved. I haven't heard of anyone having any problems with it.
__________________
Whipple Crew-10psi-Spec II-BMR LCAs-BMR sway bar delete-Spydershaft-M/T 26x11.5x17-Hurst-Prothane Mounts-PMP Line locks-Flows-Thump_rrr-Moroso separator-11.39@119mph
Daily Driver-2010 Prius-52.3mpg since new
Beater-1995 F150 XL-302 5spd
nineinchnail1024 is offline   Reply With Quote
Old 11-04-2009, 02:02 PM   #3
Vapour Trails
When you torque it to spec, it's not going anywhere.
__________________
Whipple @ 9 psi - 445rwhp/400rwtq - 12.07 @ 118.7 mph
Steeda sport springs - Steeda strut mounts - Steeda TriAx- Steeda Adjustable Panhard Bar - Steeda Axleback - D-Spec shocks - J&M LCAs - FRPP 4.10s - GT500 spoiler -
And probably more I can't remember
All work done by owner
Vapour Trails is offline   Reply With Quote
Old 11-04-2009, 09:49 PM   #4
10GTSTANG
10GTSTANG's Avatar
I was just curious, mine haas not moved. Thanks Homies!
__________________
USN Retired
46, belts, mustang, whipple
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
