Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion > 4.6L V8 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 03-27-2006, 12:20 AM   #21
matto1975
Default RE: Kenne Bell Install
I noticed you didn't say anything about fuel system upgrade. Does the KB not require any upgrade to it?
__________________
(SOLD)05GT, Saleen s/c (10lb pulley/39lb injctrs), dual pump gt500 fuel sys, Steeda alum dshaft, 3.73 FRPP, kooks long tubes with hi flos, steeda tri-ax, Eibach pro kit, spec 2+ clutch/alum flywheel, 18x10 and 18x9 deep dish bullits
458.4 rwhp
443.53 tq
1968 Coupe (rolling shell right now)
matto1975 is offline   Reply With Quote
Old 03-27-2006, 01:51 AM   #22
QuickShortBus
I ♥ Acer
Send a message via AIM to QuickShortBus
I can't wait to get a blower on my car, I am still debating between the KB, Saleen and Whipple.
QuickShortBus is offline   Reply With Quote
Old 03-27-2006, 03:47 AM   #23
sidmanic
Quote:
ORIGINAL: matto1975
that thing is sweet....I am excited about getting my blower...I just ordered the 2.3L whipple today
Should have the same kind of improvement that I just got. If you haven't ridden in a blown 05 by the time yours shows up, you'll have to rub a couple out after the first spin around the block. How do they tune the Whipple and are you doing the install?
__________________
60'=1.635 1/8=7.584 @ 90.61 1/4=12.003 @ 110.98
2500' DA.
424rwhp@399t @8psi
Kenne Bell,BMR,SLP,Eibach,Auburn,Strange,TCI,Prothane,Hu rst,Ford Racing,BFG,MT,MGW
My Garage
sidmanic is offline   Reply With Quote
Old 03-27-2006, 03:51 AM   #24
sidmanic
Quote:
ORIGINAL: lostsoul
Congrats on the KB. The unit does look awsome, but $6700 price tag is heafty.. that enters the twin turbo area or my procharger and 90% of my short block rebuild.. haha (dont ask). I just need more over time!!!
I could of had one out the door for $5600 but I had to have all the bells and whistles. What the hell, you can't take it with you.
__________________
2500' DA.
424rwhp@399t @8psi
My Garage
Old 03-27-2006, 03:57 AM   #25
sidmanic
Quote:
ORIGINAL: matto1975
Come with a Kenne Bell "Boost-A-Pump" which is used to boost the voltage of your stock pump (usually during WOT) to maintain a constant fuel pressure to the engine. They've been using them since 1997 (I think). Took about an hour and a half to install.
__________________
2500' DA.
424rwhp@399t @8psi
My Garage
Old 03-27-2006, 04:09 AM   #26
sidmanic
Quote:
ORIGINAL: 1QuickShortBus
Just do your homework and find as much info on them as you can. You never want any surprises when you are dropping that many duckets on a part. A friend of mine always says, "All of life's disappointments and frustrations come from unfulfilled expectations".
__________________
2500' DA.
424rwhp@399t @8psi
My Garage
Old 03-27-2006, 04:24 AM   #27
lostsoul
I dont blame yea.. I installed the KB pump with my procharger unit. I also used 10 guage wire for the power.. I heard that would be a very good idea. It gave me perfect fuel perssure even while my rod was exiting my block [sm=smiley18.gif]
__________________
[b]05 screaming yellow GT, shorty antenna, SLP exhaust(wow), ati procharger installed (finally). My Site http://www.trixtersracing.com/lostsoul.htm[b]
lostsoul is offline   Reply With Quote
Old 03-30-2006, 03:32 AM   #28
Skrappy
I had a Kenne Bell "Boost-a-Pump" on my '94 Lightning that I had a KB Supercharger on. So they might have been making them even longer than that.
I too find it strange that the manual did not tell you to narrow your spark plug gap? If I remember correctly, my instructions did tell me to do that. The increased cylinder pressures create a higher resistance betweent the plug electrodes and that leads to detonation. They had me bring mine in from a .44 to a .35 and that was with a MSD 6AL ignition, the old stock ones were even less due to the weaker sparks.
Skrappy
__________________
2006 Vista Blue GT 5spd
Hurst Shifter, K&N, Kicker/Infinity/Sub, spkr, etc...
Cool Beans!
Skrappy is offline   Reply With Quote
Old 03-30-2006, 03:43 AM   #29
sidmanic
That is exactly correct. The higher pressure in the cylinder requires more energy to jump the same gap. The problem is that with the higher energy needed increases the temp of the spark plug tip which could cause detonation. I got new plugs on the way now from Evolution Performance. Looks like they got the lock on the cooler plugs for right now. These are the dyno numbers I ran today.
__________________
2500' DA.
424rwhp@399t @8psi
My Garage
Old 03-30-2006, 08:27 AM   #30
CrimeScene
Nice setup,hope when you start smoking people you get some good video for us,
CrimeScene
CrimeScene is offline   Reply With Quote
2005, 23, bell, boost, install, installation, instructions, kb, kenne, kennebellcom, kenny, mustang, pump, sale, supercharger, tunes, upgrade, wiring
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
