Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion > 4.6L V8 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-08-2008, 06:32 PM   #81
ziperhead
ziperhead's Avatar
Any suggestions on how to remove the air?
__________________
06 GT Automatic, KB 2.6 Stage 2, 373 gears, Koni Sports, Steeda Ultralites
ziperhead is offline   Reply With Quote
Old 10-09-2008, 08:20 AM   #82
zkiller
2006 Ford Mustang
zkiller's Avatar
Vehicle: 2006 Ford Mustang
Let your car idle with the cap off of the intercooler reservoir for about ten minutes. When I do it, I squeeze the heater hoses that run in/out of the reservoir and heat exchanger. That helps to get the air forced out and water moving in to the lines. The pumps get noisy when they are only pushing air. Once you work the air out add some Lucas Oils Water Wetter and close it up. You can test drive and check it again if needed.
__________________
KB 2.4, KB Stage2, Level 10 , SCT, Brenspeed, 6-point rollbar, Simpson harness, GMS COPs, ST Motorports Ice box, AFCO HE, Powerhouse
11.42 & 118.92 MPH 1.63 60'
ANTI-CREW CREW
"OLD SCHOOL"
zkiller is offline   Reply With Quote
Old 10-09-2008, 04:34 PM   #83
ziperhead
ziperhead's Avatar
Thanks to Zkiller I am making headway on my intercooler pump noise. Almost all gone . Guess I need to drive it then burp it few more time.
__________________
Old 10-15-2008, 06:52 AM   #84
nycmikie
Default You Better Change That Belt Tensioner and 6 rib set up
Quote:
Originally Posted by sidmanic View Post
It's been a fun 3 days.
There were more parts not shown but you get the picture. Took 40 Hours for me and a buddy to install. Whew.
Gutted
She's pretty ugly with her makeup off.
Biggest part of the install was relocating the existing parts. Everthing from wiring harnesses, intakes, cooling lines, fuse box.... The list seemed to never end. There was a total of about 400 steps from start to finish.
The intake had to be relocated in the fenderwell next to the headlight. Had to do some cutting for this part. She gets nothing but fresh air now.
Finally done. I can't believe that this was the same engine a few days before.
You will be having lots and lots of problems
__________________
2007 Mustang GT p3 windveil blue ,Saleen body kit, aluminum Saleen hood,currie 9",bmr everything, Kenne Bell 2.6H blower in low boost 419.6 H-P, 393.4 torque RWHP, modified Saleen/kooks exh,Saleen gauge pod//mod drivers seat/tr6060 6-speed
nycmikie is offline   Reply With Quote
Old 10-15-2008, 08:17 AM   #85
zkiller
2006 Ford Mustang
zkiller's Avatar
problems? what problems?
__________________
ANTI-CREW CREW
"OLD SCHOOL"
Old 10-16-2008, 10:54 AM   #86
ziperhead
ziperhead's Avatar
I have noticed that the pictures of the installs have a right angle adaptor coming out of the drivers side valve cover . I have my demister on the line and would like to find one to help my hose not bend so much. Any suggestions on where to get one.
I also have had not issues at all with my install, Can runs perfect over the past year
__________________
Old 06-09-2009, 02:11 AM   #87
tooslow
i see no oil seperator on the left side valve cover / i get quite a bit of oil out of mine
tooslow is offline   Reply With Quote
Old 08-19-2009, 05:19 AM   #88
Skarkull
2005 Ford Mustang
Vehicle: 2005 Mustang GT
I really like the Kenne Bell kit, I have been looking at one myself. However, I cannot get past one thing, I don't like how it looks. The hose at the front is a big thing for me, it just looks so half-assed. Does anyone make a different intake that connects to the KB that removes that huge plastic intake and dryer hose. The numbers are not that far off from the Saleen, but the Saleen looks so much cleaner same for the vortech's or just about any other kit. I know the Kenne Bell has much more potential, but I really don't see me going much above a 500 hp DD, so I don't really need a kit that goes to some crazy 800 hp. But I still cannot beat the price on the KB. So again I ask, does anyone make a different intake set up for the KB?
-James
__________________
James "Trudy" Trousdale
Skarkull is offline   Reply With Quote
Old 10-03-2009, 10:19 AM   #89
Simon1
2006 Ford Mustang
Vehicle: 2006 Mustang GT
Quote:
-James
Contact Spankin Time Motorsports in San Bernardino. If you go to KB's website and read the tech articles you will see an example of one of the intake he made.
Any really good exhaust or fabricating shop could make one made out of metal if you wanted them to.
__________________
Motor Built and tuned by ST Motorsports
470/490 91 octane 10 psi
530/550 100 octane 12 psi
11.7 @122 with 1.78 60'
I'm not a member of any "Crews"
Simon1 is offline   Reply With Quote
2005, 23, bell, boost, install, installation, instructions, kb, kenne, kennebellcom, kenny, mustang, pump, sale, supercharger, tunes, upgrade, wiring
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
