New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion > 4.6L V8 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-07-2006, 03:34 PM   #1
Riggs007
Default Lets Go Turbo
So I looked around and I know nothing about Turbos. No idea which type, brand or where to get one.
Of coarse now I have a few questions...but first this is what I want the car to do...
Its not a daily driver, I want to be able to drive it downtown smoke afew guys at redlights, maybe drive to the city (250km away) to do the same, take to the track and run 11s
keep in mind that then the turbo goes on I will have completely done the internals/head/injectors/transmission and I am looking for around 600rwhp
So what should I go with:
a) Twin turbo set up vs. One big Turbo
b) Ajustable on the fly
__________________
05 GT/5pd-FR Headers,Flow master,Diablo tune, 4.10
AR Rogues, Falkin wrapped
06-F350
97-GMC 4x4-572ci-505rwhp
05-Chev-Weatherford White
05-Mastiff/Rottie cross
Riggs007 is offline   Reply With Quote
Old 09-07-2006, 04:07 PM   #2
Virgule
Default RE: Lets Go Turbo
Off the line, you'll be annihilated by the first guy running a Kenne Bell or Whipple.
__________________
2006 Redfire GT Coupe, Charcoal leather, Steeda Tri-Ax, Pypes SFM-66 Mid-Muffler System, Valvoline PowerSyn 5w-30. Next: CHE front xmember brace
Virgule is offline   Reply With Quote
Old 09-07-2006, 04:14 PM   #3
QuickShortBus
I ♥ Acer
Send a message via AIM to QuickShortBus
Quote:
ORIGINAL: Riggs007
Twin turbos just add to the cost and complexity, there is no need for twins. My car makes full boost by 2900. Adjustable Manual and Electronic boost controllers have there place but on a stock block they make it too easy to turn the boost up to a point at which your motor may blow. Stick with just a wastegate spring that keeps you between 8 and 11 psi and you will be fine. The numbers in my sig were with a heat soaked car on a hot and humid day that was otherwise stock down to the mufflers at 9 psi.
I am very happy with my PowerHouse turbo.
Quote:
ORIGINAL: Virgule
You make it evident you've never ridden in or even seen an S197 with a turbo.
QuickShortBus is offline   Reply With Quote
Old 09-07-2006, 04:17 PM   #4
Riggs007
so then if iam sitting at 400hp before the turbo i should easy hit the 600hp mark then.
It dont matter off the line, its the finish line that counts...
__________________
06-F350
Old 09-07-2006, 04:20 PM   #5
P Zero
P Zero's Avatar
Vehicle: 1993 Ranger XLT 5.0L
Quote:
ORIGINAL: Virgule
Not true, if he runs an auto trans he can make FULL boost off the line. Where as the KB or whipple have to spin up higher to make the same.
Even in a manual trans car, if you run enough boost theres nothing you wont be able to catch.
-P.
__________________
P Zero is offline   Reply With Quote
Old 09-07-2006, 04:23 PM   #6
P Zero
P Zero's Avatar
Quote:
ORIGINAL: Riggs007
Umm.... what motor you plannin on runnin 302, 351, 4.6????? Stock 302 blocks cant handle much more than 550 from what Ive heard, so you might be runnin into problems at that point. Your best bet is to run a 351W block, easy to make power, and the block is strong as hell and its basically all the same parts as a 302 with the exception of the intake, oilpan, and headers. All of which are available at jegs or summit.
-P.
__________________
Old 09-07-2006, 04:24 PM   #7
QuickShortBus
I ♥ Acer
Quote:
ORIGINAL: Riggs007
That would depend on what you are doing to get to 400hp but the 67mm turbo on my car can support 800+hp.
Old 09-07-2006, 04:27 PM   #8
QuickShortBus
I ♥ Acer
Quote:
ORIGINAL: P Zero
-P.
You do realize this is in the '05+ 4.6 specific section correct??? So one would make the assumption that he has a S197 with a 3v 4.6..........
Old 09-07-2006, 04:32 PM   #9
Riggs007
I seen afew GTs with the guts changed with over 700hp with no problems you just have to get it set up right the first time.
__________________
06-F350
Old 09-07-2006, 04:34 PM   #10
QuickShortBus
I ♥ Acer
No, the internals need to be changed if you want that kind of power. Out of curiosity can you spell out your exact plans for this car? It would help tremendously, right now it seems like you are just another person dreaming about FI and will never do it.
351, discount, mufflers, powerhouse, price, pt67, pypes, s197, sfm66, turbo
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
