Mustang 07 Gear Ratio?
Do you know the Gear Ratio for the Mustang GT 07 with Manual transmission?, the label on the door say "CG" for Axle Code, I know the "CG" is for 3.31 Limited Slip GT with automatic for 05-06 Mustang, but my pony is Manual and 07
Thanks in advance.
Thanks in advance.
RE: Mustang 07 Gear Ratio?
Thanks. But I live outside US, then my mustang is an Export Mustang, It doesn’t have Windows Sticker. My ford Certificate Label on the driver door says Axle Code “CG†in another language, but I’m sure it is the Axle Code. I know for 06 Stang GT “CG – 3.31 – Limited slip, GT with automatic transmission†but my stang in manual.
I supposed CG = 3.31 Gear ratio.Is itcorrect?
Thanks in advance
Thanks in advance
1992-2007 Ford Mustang Axle Code:
http://www.vibratesoftware.com/html_...-2007.htm#Axle
I can't found 3.23
I can't found 3.23
CG = 3.31 Limited Slip Differential [:'(]
91StangOwner
08-20-2015 11:34 PM
