Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion > 4.6L V8 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-30-2007, 08:57 AM   #1
Badazzelanore
Default Please Help-Code P061b
The engine light came on and stayed on this time. I put it on the diognostic and it showed me this code P061b. If anyone can tell me what it means it would be greatly appreciated. Incase your interested it all started whe i ran out of gas, and then when i got it filled up i had trouble starting it. Thank you I hope somone can enlighten me.
mark
Badazzelanore is offline   Reply With Quote
Old 11-02-2007, 05:28 PM   #2
scramblr
Default RE: Please Help-Code P061b
What did you pull that code with? I can't find it in the DTC listing. The only two that come close are:
P0061 - HO2S Heater Resistance
P0610 - Control Module Vehicle Options Error
__________________
12.4 @ 111mph
Saleen S/C, BGG 8 Rib, Kooks, Stingers, Spyder DS, Spec 3+, Spec Stl f/w, Pro 5.0, Ultralite Springs, Prothane Mounts, BMR - Adj. Panhard Bar, LCAs, LCA Relo Brackets, Adj. UCA, Rear Sway, Sway Delete/Rad Support, D-Specs
scramblr is offline   Reply With Quote
Old 11-02-2007, 08:04 PM   #3
Badazzelanore
I think it was the fuel pump... I read the manual and it states that in the even you run your car out of gas it may show an engile light. i unhooked the battery for two days ( i was driving my other car and forgot about it) and since I drove it today no code... I hope it stays that way. I used my sct tuner by the way. thanx
2006, code, dtc, ford, gt, mustang, p061b, sct, tuner
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
