Quick review on 4.30 Ford Motorsport gear
Hello to all,
I recently had my stock 3.55 gear changed in my 2005 GT to a 4.30 Ford Motorsports gear. The work was done by www.FordSpeed.com.
The gear was purchased through Gearhead performance http://ghspeed.com/. I could not find this gear ANYWHERE and Gear Head had it to me in 2 days, everyone else was telling me 5+ business days.
Quick run down of the cost.
Gear $199 plus tax = $212.93
Install with royal purple gear oil and extra shims. $225.00
Total $437.93 for gear and install.
Now I was debating with the 4.10 and 4.30 like everyone else. FordSpeed grabbed information from me such as tire size for street and track use, what was done to the car, and how much do I drive my car and where to.
We figured out that my setup would be good for the 4.30.
20 inch wheels 275-35-20 tires sitting around 27.35 inches for a tire. I was in 5th gear at 60mph doing 2200 RPM's. I would take a good guess that 80mph is around 3000 RPM's.
I hope this helps some people that were trying to figure out how steep the 4.30 gear is. I love the gear the car pulls pretty hard and I actually shift less since I am in 5th gear after 40mph.
Any questions for me please post and I will try to answer to the best of my knowledge.
RE: Quick review on 4.30 Ford Motorsport gear
Im guessing your speedo read a little low like mine assuming you used the factory one in the car.
Mines not a calibration error its an indexing error (likely on purpose).
Assuming 775 rpm for the tires they should be 2945 rpm at 80 mph.
That of course assumes 100% accurate speedometer and tach.
I dont think I would have been happy with 4.30's, hell, with my 4.10's its damn near impossible to get traction in 1st even when I start it off slow. I know the stock pirelli's don't help the matter, but still. But you do have 20's so that could possibly be a helping factor, anyway, anything is better than the stock 3.55's so congradulations!
Wheel diameter 17 18 Tire section 235 275 Ratio 55 40
Sidewall 5.09 4.33
Wheel + tire 27.18 26.66
Wheel width 8 8.5
Tread / Wheel 1.16 1.27
Tread - Wheel 1.25 2.33
% of OEM size 100% 98%
MPH 80 80 Axle Ratio 3.55 4.30
Transmission Gear Ratio
1 3.38 3.38 2 2.00 2.00 3 1.32 1.32 4 1.00 1.00 5 0.68 0.68
Engine RPM
1 11,872.57 14,659.05 2 7,025.19 8,674.00 3 4,636.63 5,724.84 4 3,512.60 4,337.00 5 2,388.57 2,949.16
Sidewall 5.09 4.33
Wheel width 8 8.5
Engine RPM
I messed it up earlier. Try this.
Ratio 55 40
Sidewall 5.09 4.33
Wheel width 8 8.5
MPH 80 80
1 3.38 3.38
2 2.00 2.00
3 1.32 1.32
4 1.00 1.00
5 0.68 0.68
Engine RPM
1 11,873 14,659
2 7,025 8,674
3 4,637 5,725
4 3,513 4,337
5 2,389 2,949
Ratio 55 40
Sidewall 5.09 4.33
Wheel width 8 8.5
MPH 80 80
1 3.38 3.38
2 2.00 2.00
3 1.32 1.32
4 1.00 1.00
5 0.68 0.68
Engine RPM
1 11,873 14,659
2 7,025 8,674
3 4,637 5,725
4 3,513 4,337
5 2,389 2,949
NorthAmericanTuning
03-18-2016 11:21 AM
Greyshot
08-15-2015 03:32 AM
