Loud squeaking noise from rear suspension - MustangForums.com
Old 10-08-2015, 02:45 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering & Suspension Guides
Print Wikipost
Old 02-28-2009, 10:24 PM   #1
notsofast
notsofast's Avatar
Default Loud squeaking noise from rear suspension
Any help here would be greatly appreciated.
I have a 2006 GT, 5-sp manual, that has developed a loud, very annoying "squeaking" sound that seems to be coming from the passenger side rear suspension. The noise occurs whenever the car is in motion, fore-aft, up-down, regardless of whether drive train is engaged or while coasting, not related to braking. I have aftermarket (Metco) LCAs and FR springs (same as the Eibach Pro-Kit).
I took it to the dealer and their diagnosis was "rocks in the exhaust pipe," which they dutifully extracted. Naturally, I was more than a little skeptical that the exhaust-pipe-rock-extraction would cure the problem. After driving the car home, the rocks must have worked their way back in, as the annoying sound has returned.
I don't know the cause, but I would think it might be a worn bushing or perhaps a shock (they are OEM, not aftermarket) based on how it sounds to me.
Any thoughts or ideas?
notsofast is offline   Reply With Quote
Old 02-28-2009, 10:34 PM   #2
gman73
gman73's Avatar
I believe most if not all mustang owners have or will have this problem. I also hear a squeaking noise coming from the rear. At first it was from the passenger and now both sides. I talked to a guy today who was an 06 Mustang GT and asked him about it. He said he took his car in and he was told there was nothing they could do. The mechanic said it was due to flex. He was told new shocks and struts wouldn't help.
gman73 is offline   Reply With Quote
Old 02-28-2009, 10:51 PM   #3
notsofast
notsofast's Avatar
Gman,
Thanks for the post, however depressing it may be. I hope it can be fixed - I don't think I can live with it as a daily driver.
Old 02-28-2009, 11:05 PM   #4
gman73
gman73's Avatar
I know you said you notice it while in motion. Do you notice it at all speeds or when driving slowly? I mostly notice the squeaking when going slow and especially over speed bumps. At cruising speeds, I hear it only once in while.
Old 02-28-2009, 11:28 PM   #5
notsofast
notsofast's Avatar
It is more noticable at low speeds. I think it is also there at highway speeds, but road noise obscures it to some extent.
Old 11-08-2011, 03:10 PM   #6
dirtychamba
Did any of you fix this? I know my tokico dspecs and eibach springs did NOT!!!!!!
dirtychamba is offline   Reply With Quote
Old 11-09-2011, 12:15 AM   #7
05windviel
05windviel's Avatar
my guess is it could be the swaybar bushings? i know my v6 when i added the rear sway with poly bushings it started squeaking
05windviel is offline   Reply With Quote
Old 11-10-2011, 05:52 PM   #8
sactown
sactown's Avatar
have you tried put some of that silicon lube on the LCA's? My BMR LCA'S have grease fittings I add grease once a year.
sactown is offline   Reply With Quote
Old 11-10-2011, 06:28 PM   #9
JCON
JCON's Avatar
get poly bushings and make sure you fill the grease trays inside the bushing. coating the inside with a disgusting amount of grease isn't going to hurt you. I did this on my old V6 and never heard a squeak out of it
JCON is offline   Reply With Quote
Old 11-13-2011, 05:12 PM   #10
kevilay
I had a loud squeeking on my rear suspension and it ended up being the sway bar bushing, poped the caps off them greesed them up and i was good to go
kevilay is offline   Reply With Quote
Switching from 3.89 to 3.00 gears... musnicki Classic Mustang General Discussion 8 09-23-2015 08:11 AM
Pinion angle, poly bushings, 1 piece DS mtgldr S197 Handling Section 1 09-10-2015 10:43 PM
Loud Noise Above 30 MPH bjdutch2005 2005-2014 Mustangs 8 09-07-2015 11:05 PM
03 V6 Mustang Ticking Noise Emblazoned General Tech 0 09-03-2015 11:45 PM
back, camaro, drive, fox, loud, making, mustang, noise, rear, shocks, sound, squeak, squeaking, squeaks, suspension
