Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion > 4.6L V8 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 03-22-2009, 09:43 AM   #11
kcmarti
kcmarti's Avatar
Quote:
Originally Posted by provofam View Post
kcmarti, thanks for the reply I travel alot as well and my stang is my daily driver. I love this car and definitely want to drive it for many years to come. By the way, how's it drive after that many miles?
Runs as strong today, with 101K+ miles on the odometer, as it did when I picked it up with 2.4 miles on the odometer. And it is not babied all the time - I do 10 to 20 trips to the track each season in addition to being a DD.
__________________
06 GT Vista Blue 64Ws Manual
Sequentials, 50F/35R Metallic Tint, JBA Shorty Headers, JBA Exhaust, BamaChips Tunes, JLT-II CAI, Hurst Shifter, Roush Front End
kcmarti is offline   Reply With Quote
Old 03-24-2009, 09:05 AM   #12
provofam
provofam's Avatar
Vehicle: 2008, Ford, Mustang
Well, I got home yesterday (Monday) after placing the order on Friday and the oil was waiting for me on the doorstep. With work and family time being hectic I'm hoping to get the oil changed sometime this week. It is interesting that the mileage improvements could be from the differential change. I'm hoping to install 4.10 or 3.73 gears soon and will definitely buy Amsoil's diff oil for the shop's install.
__________________
08' Mustang GT, MT, stock 3.31 gears (for now), Steeda CAI, Brenspeed 91 tune, Flowmaster A/B, Pypes O/R H pipe, and more mods to come later
provofam is offline   Reply With Quote
Old 03-24-2009, 04:49 PM   #13
SCCAGT
2006 Ford Mustang
If you get Amsoil gear oil, you MUST use their slip-lock additive.
I already tried SevereGear without any additive (suppose to be in it already). Within 2 days I had chatter. Went to the local parts store and added their additive. This time it took 2 weeks before chatter came around. That time, I changed the whole thing out again with Severe Gear and Amsoil Slip-lock, and haven't had a problem since.
You need 2 qts of oil plus the additive.
__________________
06 GT, Yellow, Automatic
Procharger, 10psi, 459rwhp, 384trq
3"MagnaFlow Exhaust
BBK Headers
SSB Brake lines
Authorized Distributor of:
ProCharger, Magnaflow, and Amsoil products
SCCAGT is offline   Reply With Quote
Old 03-28-2009, 04:20 PM   #14
provofam
provofam's Avatar
Thanks for the info, I'll definitely make sure that I get the Slip-lock when I change out gears
__________________
Old 04-02-2009, 12:03 AM   #15
ShadyNinja
2005 Ford Mustang
ShadyNinja's Avatar
Vehicle: y2k v6 /2005 gt
Send a message via AIM to ShadyNinja Send a message via Yahoo to ShadyNinja
yeah I added the slip lock to mine too
its better to use it and not need it, than to not use it and need it.
ShadyNinja is offline   Reply With Quote
Old 04-04-2009, 10:58 PM   #16
algregory
Been a synthetic user for nearly 30 years. Used Redline in CA for many of them. Moved to NC, no more Redline. A CA friend of more than twenty years has always been an Amsoil fan, that is what I chose for NC.
Changed the '05 GT at it's 5k interval the first thing I noticed when I started it is that I'm DAMN SURE that if runs quieter! I also chaged out the 5 speed with Amsoil ATF and "Tufoil" an additive I've been using for about 200k after the machinist that built my last car recomended it. Six ounces Tufoil in the engine, and a 10% mix in the transmission. Sticking with 5k interval on the GT.
My '89 GMC now has 179k on it. In CA with 4k intervals of Redline it used about 1 quart per 4k miles. Now coming up on it's third 8k interval in NC with Amsoil 10W-30. Those first two changes I bought a spare quart for useage. This time I only bought three quarts because the "spare" two quarts never got opened! Also use Tufoil in the GMC.
My '04 Yamaha FJR1300ABS got introduced to Amsoil Cycle Oil 10W-40 yesterday! I'm DAMN SURE it is quieter also! It sounds like it has hydraulic lifters for pete's sake! Also changed out the differential for an Amsoil gear lube the same time. Sure sounded pretty on today's 100 mile ride. Also use Tufoil in the FJR.
Won't change from Amsoil, won't change from Tufoil.
__________________
05 GT - Screaming Yellow
Granatelli CAI
algregory is offline   Reply With Quote
Old 04-05-2009, 10:32 PM   #17
StickShifty
2008 Ford Mustang
StickShifty's Avatar
Vehicle: 2008 GT/CS
Send a message via AIM to StickShifty
why not use 5w20?? i have never used amsoil, might try switching over to it.
__________________
2008 Performance White GT/CS - Build Date: 2/15/2008 - Tuned by Brenspeed/C&L Intake/SCT Tuner/Corsa/FRPP Springs/Tokico Shocks/BMR Strut Brace /BMR LCAs/BMR Brackets/Steeda Pan. Bar/FRPP Cam Covers/Bullitt Grille w/ Tri-Bar Pony/8" Shorty Antenna/Hood Struts/CS Stripe Delete/Clear Corners/White Shift Ball w/ Grabber Pony Collar/Sat Radio/S2000 Start Button/Altec Front Plate Mount
StickShifty is offline   Reply With Quote
Old 04-06-2009, 07:02 AM   #18
algregory
Quote:
I'm using 0W-20 Amsoil. New stuff, better, it be said. Amsoil guy showed me specs on the oils, I'm not a "tech", but there were a set of numbers in there that said the weights were not that far different, but the "0" had some good attributes.
__________________
Granatelli CAI
Old 04-06-2009, 04:00 PM   #19
SCCAGT
2006 Ford Mustang
Amsoil does not have a 5W20 in full synthetic. They only offer it in their XL7500 line.
The difference between 0W and 5W is cold weather pour point. Once at operating temperature, both oils perform like a 20.
__________________
3"MagnaFlow Exhaust
BBK Headers
SSB Brake lines
Old 04-06-2009, 04:42 PM   #20
torrediruggiero
Vehicle: 2008, FORD, MUSTANG GT
Quote:
Originally Posted by Goldenpony View Post
I switched to AMSOIL after using (and being satisfied with) Mobil 1 for many years. I just became convinced AMSOIL was the very best. I use 0W20 along with their Ea filter. I am doing the 10K mile change.
I thought that my 2008 Mustang GT took 5W20?
torrediruggiero is offline   Reply With Quote
07, 0w20, 2006, amsoil, buy, chatter, filter, group, gt, jersey, manual, motor oil, mustang, procharger, s2k, transmission
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
