Driveshaft loop over Spydershaft.
Old 04-17-2009, 11:50 AM
explict
explict's Avatar
Default Driveshaft loop over Spydershaft.
So I am looking to get a driveshaft loop for my 4"-3.5" Spydershaft.
I was looking at the BMR one, but I, nor Brenspeed, are sure if it will fit over the Spydershaft.
They say it fits over their 3.5" Dynatech shaft without a problem.
Anyone know if it will fit?
explict is offline
Old 04-17-2009, 09:03 PM
AmericanSpeed
AmericanSpeed's Avatar
I also am curious as to weather it will fit. Explicit are you lowered? That may cause problems as well.
Does anyone have a loop, is lowered, has a sypdershaft and has the MGW shifter?
AmericanSpeed is offline
Old 04-19-2009, 09:39 PM
rjg426
rjg426's Avatar
I just installed a Shaftmasters 3.5-4" alum shaft with the BMR front loop. No problems; the loop fits around the short 3.5" area right after the boot and before the 4" area. The Spydershaft I believe is the same setup. The BMR loop has slotted holes for left-right adjustment but not really up-down. My car is not lowered.
rjg426 is offline
Old 04-20-2009, 03:15 AM
onederful100
onederful100's Avatar
i have the BMR DS safety loop w/ the spydershaft and it fits. but 1 problem w/ my BBK o/r x pipe (i also have BBK LT's), the loop was contacting my x pipe and i was getting vibration, so i had to modify the x pipe to get more clearance now its fine. i've heard of 1 other person w/ this problem w/ the BMR loop and o/r x pipe, but most others have no problems.
onederful100 is offline
Old 04-20-2009, 11:27 AM
AmericanSpeed
Onederful, is your car lowered? are you auto or manual? if you are manual, which shifter do you have?
where exactly does the bmr loop go around the shaft? Is it even in the area of the shifter? I'm worried that since the MGW is adjustable (unscrewing, which lowers the bottom and shortens the throw) will cause a clearance issue.
Old 04-20-2009, 12:57 PM
rjg426
rjg426's Avatar
TacoBill has a nice write-up a while back on his installation of the Coast 4" driveshaft, BMR loop and MGW shifter. I believe had had some interference problems that he corrected with custom shims. Check it out: https://mustangforums.com/forum/2005...ll-w-pics.html
rjg426 is offline
Old 04-21-2009, 03:53 AM
Diabolical!
Diabolical!'s Avatar
I have the spydershaft and the BMR loop. The only problem I had was that the loop was contacting my hurst shifter in certain gears. I fixed the problem by machining a spacer for the loop.
Diabolical! is offline
Old 04-21-2009, 08:56 AM
AmericanSpeed
Nine, you aren't lowered are you?
Old 04-21-2009, 09:03 AM
AmericanSpeed
Thanks for the link, that answered all of my questions
Old 04-24-2009, 03:03 AM
Diabolical!
Only when I've got bodies stuffed in the trunk, lol.
Stock suspension except for LCAs.
mtgldr
02-03-2024 09:00 PM
baddog671
07-26-2016 01:20 PM
Boostaddict
2.3L Eco-Boost Tech
11-24-2015 06:11 AM
Matt's 95 Stang
10-05-2015 07:16 AM
FivePointToTheOh
09-14-2015 03:35 PM
Quick Reply: Driveshaft loop over Spydershaft.
