Old 11-20-2015, 12:20 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Transmission Guides
Print Wikipost
TR-3650 gear ratios?
Old 04-30-2009, 09:34 AM
JasperGT
JasperGT's Avatar
Default TR-3650 gear ratios?
Does anyone know what the gear ratios for the Tremec TR-3650 5 speed manual transmission are for the 2005-2009 GT mustangs? I have found some ratios, but the 5th gear ratio does not seem to have a consensus. Do these transmissions have different gear ratios for the different years? Also, what is the specific Tremec part number?
These are the numbers that I have found from some other forums:
1st: 3.340:1
2nd: 2.000:1
3rd: 1.320:1
4th: 1.000:1
5th: 0.670:1
Rev: 3.380:1
Are these right?
JasperGT is offline
Old 04-30-2009, 09:54 AM
Nuke
Nuke's Avatar
Here's what I have:
1st 3.38
2nd 2.0
3rd 1.32
4th 1.0
5th 0.675
Don't know about reverse.
Nuke is offline
Old 05-02-2009, 12:04 PM
JasperGT
JasperGT's Avatar
I've seen those numbers on other forums.
Thanks Nuke!
JasperGT is offline
Old 05-02-2009, 12:22 PM
AmericanMuscle4.6GT
AmericanMuscle4.6GT's Avatar
i think the auto has a 5th gear ratio of .67, the manual has a .62?
AmericanMuscle4.6GT is offline
Old 05-02-2009, 01:33 PM
Nuke
Nuke's Avatar
For the auto, I'm showing:
1st 3.22
2nd 2.29
3rd 1.54
4th 1.00
5th 0.71
And, of course, I found another spreadsheet with slightly different #'s for both. Sheeesh.
Nuke is offline
Old 05-03-2009, 10:12 AM
BruceH
BruceH's Avatar
A link to the Tremec website: http://www.ttcautomotive.com/English...ts/TR-3650.asp
BruceH is offline
Old 05-04-2009, 09:19 PM
SlideWRX
SlideWRX's Avatar
Some previous model year Mustangs have the 0.62 5th gear. We have 0.675. I'd like to have the 0.62 to save some gas on highway mileage.
SlideWRX is offline
Old 05-05-2009, 11:54 AM
bynumj
bynumj's Avatar
Default Gear Chart
I have an excel chart that has the gears for 05+ auto, 5-speed, and 6-speed; it will also calculate RPM and MPH for the drivetrain. I need to figure out how to post it.
bynumj is offline
Old 04-23-2012, 04:48 AM
wayne613
wayne613's Avatar
Trying to get my final gear ratios down for an ODB-II program that uses all of this data to give me a decent dissection of what/how/why (Dashcommand).
So another necromancy resurrection by me...
1-4 for the revisions are the same, so no worries, but 5th just seems to be up in the air: .62 for earlier, .68 for some later in the 05-09 realm, and even .74 for some.
There a way to tell short of yanking the transmission which part # mine would have? I suppose I could just cruise in 4th, get to a set speed, then shift into 5th and calculate it out, but...
In my case, 08 GT manual. I'm guessing .68...
References:
http://en.wikipedia.org/wiki/Tremec_...0_transmission
wayne613 is offline
Old 04-23-2012, 07:27 AM
S197GT07
S197GT07's Avatar
Correct, the only way to really tell is to take down your tire size, and find out what rpm you are at when cruising at XXmph in 5th. I'd use a GPS to get that XXmph, not using the speedo though.
S197GT07 is offline
Quick Reply: TR-3650 gear ratios?
