Random misfires CMP sensor?
Old 05-07-2009, 04:04 PM
Tjeppelin
Tjeppelin's Avatar
Default Random misfires CMP sensor?
Ok heres the deal. This all started out as what i thought to be the fuel pump TSB but after trying a GT500 fuel pump and than just putting a brand new stock pump on the problem was still there, which was hesitation after a long highway cruise. Now the problem has progressed to throwing random misfire codes every once and awhile, and what seems to me to be a loss in low end torque. I tried MAF cleaner and just took it for a drive and no codes but the power loss still seems to be there. Anyone have similar situation codes were p0300 p0304 p0306 and p0340 the last is a new one and its got something to do with the CMP (Camshaft Position Sensor)sensor A circuit malfunction, I'm pretty sure this might be causing it but where do I go from now do I just buy a new one and replace it or is the a way I can test it. Any help would be greatly appreciated.
Tjeppelin is offline
Old 05-07-2009, 08:38 PM
2007VistaBlueGT
2007VistaBlueGT's Avatar
A test of the entire circuit must be conducted. You musta make sure there is proper voltage and continuity before replacing the cam sensor, you also should check the crank sensor.
2007VistaBlueGT is offline
jwog666
12-27-2021 08:09 PM
mrtrodonet
09-19-2020 03:12 PM
Omgitsa88Stang
10-05-2015 07:33 AM
Dathan
10-05-2015 05:52 AM
ChampInSD
10-02-2015 04:55 AM
Quick Reply: Random misfires CMP sensor?
