Clutch Slave Cyl Bleedscrew Location?
I was doing some preventive maintenance on my '06, five speed GT this past weekend. I went to flush the brake and clutch fluid and couldn't find a bleed screw for the clutch slave cylinder. I had to settle for flushing the brakes, but there seems to be a pocket in the reservoir for the clutch that retained some of the old nasty fluid. I sure would like to flush the clutch.
If I am correct, I found the slave cylinder hydraulic connection at the top of the bell housing, but couldn't find a bleed screw anywhere.
Can anyone steer me to it?
Thanks in advance for the help.
Doc
Doc
Thanks for the info nineinchnail.
This is REALLY disappointing. I expect that air can make its way out just by rising through the lines if they are arranged properly. The problem is flushing it. I have learned that flushing clutch and brakes every few years eliminates the need to ever rebuild any hydraulics. Without the capability to flush them I guess you're just destined to replace the throw out pack at one time or another.
BAD design IMHO!
Thanks again,
Doc
BAD design IMHO!
Thanks again,
Doc
BAD design IMHO!
Thanks again,
Doc
BAD design IMHO!
Thanks again,
Doc
Matt's 95 Stang
10-05-2015 07:16 AM
junior04
09-28-2015 10:53 AM
