New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion > 4.6L V8 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-02-2009, 04:06 PM   #21
vasman
vasman's Avatar
Vehicle: 2007, GT CS, Convertible
Did you use a pump to put refill or you can fit the bottle up there?
__________________
2007 GT/CS Convertible
Techco 3L Twin Screw SC @10 PSI
Kooks LTs H-pype hiflow cats, Borla Stingers
4.10 FRRP Gears, Dynotech 3.5 Aluminium Drive shaft
Steeda Superlights, Tokico D Specs, BMR-UCA/LCA-Relo Braket- Adj.Panhard bar
CHE K Brace with torque limiters, Ford Racing STB
MGW shifter, Dual GT500 Fuel pump,
Nitto 555 245/45/18, 285/40/18 on 9&10" Omega GS Black Chrome
vasman is offline   Reply With Quote
Old 06-02-2009, 05:50 PM   #22
degeze
2006 Ford Mustang
degeze's Avatar
Vehicle: "KNTMARE"
^ I didn't use a pump and there is not enough room to put the bottle into the fill hole, so I used a 6' plastic tube. I inserted one end of the tube into the fill hole and attached the other to the nozzle on the gear oil bottle. Then I held the bottle upside down and squeezed it until empty...continuing with more bottles until level with the fill hole. Works great .
You could use a pump but it didn't seem necessary to buy if I didn't already have one laying around.
__________________
2006 Premium Mustang GT
5 Speed | 3.55 Gears | BMR Suspension | Bumpsteer Kit | H&R Super Sport Springs | Konig Beyond 18s |
Foose Stallion Hood | Cervini Type III Chin Spoiler
degeze is offline   Reply With Quote
Old 06-02-2009, 06:39 PM   #23
Rubrignitz
2007 Ford Mustang
Rubrignitz's Avatar
Vehicle: 2007 Mustang GT Coupe
For you guys that are considering a rear cover with drain holes... I've been holding off on my fluid swap until I found the perfect cover and there only seems to be one kind that allows for the use of the stock location panhard bar, LPW http://www.lpwracing.com/. They are also sold by Steeda. I really didn't want to have to relocate my panhard bar and this seems to be the ticket to a drain-hole cover w/o relocation bracket for the panhard. I ordered one this week. Just thought I would add that info to this great how-to thread. I also vote this one a sticky. Great pics and writeup! And a nice clean undercarriage helps .
__________________
2007 Alloy GT Coupe/5M/MGW w/ball/C&L Racer CAI/JBA LT's/JBA catted H/Pypes M-80 race mufflers/Steeda HD engine mounts/LFP 17# Driveshaft/FRPP 4.10s/Truetrac/Steeda Ultralite 18x9.5's with 275/40 and 285/40 Nitto NT555s/Autometer DPSS shift light and gauges. Suspension: Steeda Competition Springs/GT500 Front CA's with X5 balljoints/Bumpsteer Kit/D-Specs/BMR adj upper & lower LCAs + relocation brackets/Hotchkis 3/4 way adj swaybars/UMI Performance panhard.
Rubrignitz is offline   Reply With Quote
Old 06-02-2009, 06:45 PM   #24
Rubrignitz
2007 Ford Mustang
Rubrignitz's Avatar
You can also use this method to swap your tranny fluid. Remove your shifter boot, run the tube down into the tranny fill hole. Works great, especially with Royal Purple's style of container with the nice stepped cap that fits tight up into the tube. I'm going to use an old RP bottle to get the Amsoil (which comes in a regular type oil container) into the rear diff when I do mine...
__________________
Old 06-03-2009, 08:15 AM   #25
degeze
2006 Ford Mustang
degeze's Avatar
Vehicle: "KNTMARE"
^ This is the same method I used to change my tranny fluid a few weeks back. Here is the How To for the tranny fluid change for anyone interested.
__________________
Old 06-03-2009, 12:28 PM   #26
vasman
vasman's Avatar
I did it yesterday. I bought a hand pump from O'railly's for 8 bucks. It looks like a large soap dispenser. It is called Hand pump for Quarts or Gallons. It screws right on the Royal purple bottle. It worked like a charm. (about 30 pushes to the bottle but a lot easier than squeezing etc... really cool gadget). Used the longer tube to reach all the way to the bottom of the royal purple. No mess at all.
__________________
Old 06-03-2009, 12:39 PM   #27
degeze
2006 Ford Mustang
degeze's Avatar
Vehicle: "KNTMARE"
^ Glad everything worked out .
__________________
Old 06-03-2009, 01:17 PM   #28
bigray327
bigray327's Avatar
Great write-up, thanks.
So there's no such thing as overfilling the differential fluid, since you fill it to the top, right?
__________________
bigray327 is offline   Reply With Quote
Old 06-03-2009, 01:18 PM   #29
bigray327
bigray327's Avatar
Quote:
FYI, here's a new one from Fore Precision Works. $349... yikes.
http://www.foreprecisionworks.com/0058-100.html
__________________
Old 06-03-2009, 01:39 PM   #30
degeze
2006 Ford Mustang
degeze's Avatar
Vehicle: "KNTMARE"
You're welcome, and you fill it until the fluid is level with the bottom of the fill hole.
That thing looks like it belongs on a robot...I'll pass.
__________________
2000, 88, axle, capacity, change, change differential fluid, diff, differential, faint, fluid, mustang, noise, noisy, normal, oil, rear, rear axle fluid, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
