Last edit by: IB Advertising
Browse all: Transmission Guides
- Ford Mustang Gt 1996 to 2004: How to Change Differential Fluid
Step by step instructions for do-it-yourself repairs
How To: Change Differential Fluid
#72
I looked for some friction modifier but I couldn't find anything that said it was XL-3 locally and if Royal Purple doesn't need it that would be one less thing to worry about.
Edit: According to the RP site you don't need the friction modifier - http://royalpurple.com/faqs-transmission.html
2nd Edit: Got done, easy as pie. I didn't use any tubing, though I did have it on a rack with the rear end dropped down which gave me enough space to bit the bottle at a slight angle above the driveshaft.
#73
Glad I could help out fellow MFers , and thanks Cameron.
candymanjl- I have heard nothing but good things about Redline lubricants, but let me tell you I changed my tranny fluid out a few weeks back to Royal Purple Synchromax and love it. The tranny temp has gone down, it's quieter and smoother shifts are awesome.
As far as the drain plug, I don't know what Ford was thinking .
If anyone doesn't want to use RTV for the cover, you can get a nice reusable gasket here.
http://www.quadratec.com/products/52416_110.htm
I put that on when I had my 4.10's installed many moons ago and it will probably outlast the car.
#74
I am about to do this, curious if the above is true?
#75
#76
While you're under there, and you notice some oil residue on the passenger side axle, you could change the axle vent. Ford has a TSB on it and the dealer sells them - I think I paid ~ $70. The factory vent is a small assembly on top of the axle (about 1/2" round and 1/2" high) and is about 1/2 way between the diff and the brakes . The new one looks sort of like a fuel priming bulb and it is designed to catch the oil vapor and allow it to drip back into the axle thus avoiding the oil mess on the axle. It is working so far.
#80
Thanks for this awesome instructions!!! After reading it over a few times I was fully confident in doing it with no help or review!!
I used royal purple and the additive. Only took me about 1 hour. I had a problem filling it back up, but I got a pump and it worked great. I had a little trouble getting the case back on without touching the gasket to the gears, but going very slowly and entering from the passenger side I was able to get it on without touching.
I used the orange hi temp gasket maker
