Thumper cams
Old 08-03-2009, 12:14 PM
Darren05
Darren05's Avatar
Default Thumper cams
Is it required to have 3.73 gears or higher to install the Thumper cams? I know the performance would not be as great as if it had the 3.73's or 4.10's but what I would like to know is if it would hurt my car. I plan on putting the 4.10's in around November but would like to install the cams next month. If it will hurt the car then I will go ahead and get the gears first and get the cams at a later date. I just have the money now to get the cams and am afraid that if I do not get them now I will spend the money on a whole bunch of other stuff for the car that I could probably live without.
Darren05 is offline
Old 08-03-2009, 12:20 PM
CorruptedDemon60
CorruptedDemon60's Avatar
I dont know the answer. But I'm sure if you call Brenspeed. They can tell you what support mods you will need with the cams.
CorruptedDemon60 is offline
Old 08-03-2009, 12:25 PM
mrtstang
mrtstang's Avatar
It will be fine. I know a guy who has these cams on his 06 gt with stock gears and stock headers.
mrtstang is offline
Old 08-03-2009, 12:45 PM
abarker8541
abarker8541's Avatar
your low rpms will just have no power. once you get up high you will be fine. i would go ahead and do gears man but hey its your money. you wont hurt the car i dont think just lose a lot down low.
abarker8541 is offline
Old 08-03-2009, 04:01 PM
gremlin190
gremlin190's Avatar
Basically what Barker said.
You may lose some low end torque, but you power band will not fall off as fast as stock cams. The reason for the 4.10 gears isn't due to damaging your car, but to compensate for the loss of torque down low.
I'm suppose to be getting some frpp hotord's installed this week. woo hoo
gremlin190 is offline
Old 08-03-2009, 04:35 PM
overcome1236
overcome1236's Avatar
how much do cam installs usually run?
overcome1236 is offline
Old 08-03-2009, 08:12 PM
Darren05
Darren05's Avatar
Thanks for yall's help. I am getting the gears around September or October, just wanted to install the cams now. I will be doing the install myself, my buddy just did his and he said it was real easy. I will let yall know how it turns out.
Darren05 is offline
Old 08-04-2009, 10:33 AM
gremlin190
gremlin190's Avatar
Usually about 4 hours labor
GimpyHSHS
19
12-19-2023 01:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Quick Reply: Thumper cams
