Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion > 4.6L V8 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-05-2009, 09:57 PM   #1
top00cat
Vehicle: 2008 gt
Default Mustang Harmonic Balancer
Does anyone know how to find the keyway in the harmonic balancer without taking the bolt out? I am currently doing hot rod cams and cant find the 12 o'clock position because the harmonic balancer is not stamped or groved
top00cat is offline   Reply With Quote
Old 08-05-2009, 11:41 PM   #2
hammeron
hammeron's Avatar
Vehicle: 2006 GT
if you look closely at the crankshaft pulley
inner edge, you should see a small cut. this
is the timing mark and the damper spoke just to
the left of it, will be what you set to the 12 and
6 o'clock positions.
hope this helps and good luck with the project.
hammeron is offline   Reply With Quote
Old 08-06-2009, 12:53 PM   #3
top00cat
Vehicle: 2008 gt
hammeron, right after I read your reply I found the grove right away. I was originally looking on the outer edge and couldnt find it. Your help is much appreciated. Did you do the cams too?
Old 08-06-2009, 01:02 PM   #4
top00cat
Vehicle: 2008 gt
after you remove the followers on the right hand side did you turn the crank to remove the followers on the left hand side?
Old 08-06-2009, 04:45 PM   #5
hammeron
hammeron's Avatar
Vehicle: 2006 GT
sorry top00cat been on the road...
here is a step by step for the hot rod cams
http://home.comcast.net/~cookpaging/...otrodcams.html
let me know if you run into any other issues, hopefully
i can respond quicker next time
__________________
2006 GT Supercharged
Whipple Crew
FRPP Hot Rod Cams
M-5230-S (KR's)
Old 08-06-2009, 04:56 PM   #6
top00cat
Vehicle: 2008 gt
I am new to this forum stuff so I dont really know how it works. But your advice has been much help
Old 08-06-2009, 04:58 PM   #7
hammeron
hammeron's Avatar
Vehicle: 2006 GT
hey i'm here for ya and it's always fun
when another person joins the hot rod
cam crew
Old 08-06-2009, 05:00 PM   #8
top00cat
Vehicle: 2008 gt
yeah from what I saw on youtube they sound great. cant wait to hear them in person. what kind of gains did you see from them?
Old 08-06-2009, 05:14 PM   #9
hammeron
hammeron's Avatar
Vehicle: 2006 GT
for me they were strictly a sound mod, i was already
running at a comfortable power level (450) and didn't
need any more.
with a dyno tune you may see a 20-30rwhp gain.
Old 08-06-2009, 06:01 PM   #10
top00cat
Vehicle: 2008 gt
Its pretty much a sound mod for me too. I went with the bamachips tune for them so I shouldnt gain too much. I will let you know how they turn out when I am done. Thanks again for all the help
2000, 2005, 351, 46l, 98, balance, balancer, bolt, change, ford, gt, harmonic, keyway, mustang, remove, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
