Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion > 4.6L V8 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-04-2009, 11:18 PM   #1
bsimecka
Vehicle: 1999 Ford Mustang GT
Default Fuel rail removed now will not start
Removed fuel rail to replace intake manifold. Replace everything and now it will not start. I did not have the fuel rail secure and was loose.... now I can not get car to fire... will turn over fine and fuel pump is fine.. I am guessing that I did not have proper fuel pressue and computer prevented it from starting.... ?? Help please.
bsimecka is offline   Reply With Quote
Old 09-04-2009, 11:21 PM   #2
BruceH
2008 Ford Mustang
BruceH's Avatar
Vehicle: 2008 Mustang GT/CS
Have you tried disconnecting the battery for a half hour?
__________________
2008 GT/CS 5 Speed
Control Arms, Prothane MM's
Aluminum DS, McLeod RST/Fidanza FW
FRPP Ceramic Shorties
FRPP Whipple HO
Built Motor
Whipple Crew
BruceH is offline   Reply With Quote
Old 09-05-2009, 12:32 AM   #3
Simon1
2006 Ford Mustang
Vehicle: 2006 Mustang GT
I would go through the entire reassembly process again and make sure everything was put back together correctly.
__________________
Motor Built and tuned by ST Motorsports
470/490 91 octane 10 psi
530/550 100 octane 12 psi
11.7 @122 with 1.78 60'
I'm not a member of any "Crews"
Simon1 is offline   Reply With Quote
Old 09-06-2009, 01:04 AM   #4
nineinchnail1024
Stupid question, but did you reconnect the wires to the fuel injectors?
__________________
Whipple Crew-10psi-Spec II-BMR LCAs-BMR sway bar delete-Spydershaft-M/T 26x11.5x17-Hurst-Prothane Mounts-PMP Line locks-Flows-Thump_rrr-Moroso separator-11.39@119mph
Daily Driver-2010 Prius-52.3mpg since new
Beater-1995 F150 XL-302 5spd
nineinchnail1024 is offline   Reply With Quote
2008, 46, 50, 99, disconnect, ford, fox, fuel, install, mustang, rail, rails, starting, stock, v6, v8
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
