I'm looking at the delete plates from steeda. They offer two types, billet and economy. However they both claim to increase about 10hp. Is there a difference between the two that make it worth it to spend the extra money for the billet ones?
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________ 06 Yellow GT 5 Speed. Pro 5.0 shifter, Steeda HD rear sway bar with billet end links, Steeda front sway bar, Steeda UDP, BMR combo adj LCA's, BMR combo UCA, BMR adj panhard bar, K&N CAI, Steeda strut tower brace, Magnaflow Magnapack cat back, BAMA chips SCT, Ford Racing 4.10's, Sequential tail lights, Shorty antenna, Silverhorse Racing rear center cover.
Get the economy ones. Don't waste your money like I did on the billet ones. Both perform the same function, which is eliminating those flimsy valves out of the air path.
The only scenario I see where the billet ones would be useful would be if you're installing nitrous and get the CMCV with the N2o ports pre-drilled unto them.
Don't forget to update the tuning.
__________________
2008 Black GT/CS auto
VMP Tuning 93 oct tune - Steeda CAI - CMCV - UDP's - Strut-tower brace - HD motor mounts - Aluminum D/S - ARH LT headers /w catt'd xpipe - Borla Stingers - Granatelli Dimpled/Slotted rotors - Eibach swaybar kit - Sequential taillights
+1. there really is no difference in performance gains.
__________________
Procharged 10PSI H.O. Intercooled
498whp/445wtq
For sale: plasma booster ignition
Quote:
Red Turbo Integra
That's the plan. The only thing that sucks is I have a dentist apointment in the morning. Hopefully all the numbing sh1t wears off quick so I don't look like a retard drooling on myself.
OR, you can be even cheaper by just having your tuner adjust the valves to where they are always open. Still have the valves in the way, but at least you get rid of the annoying delay.
That doesn't sound safe at all.
Are you running that way with that Paxton kit? Better hope those valves don't catch some of that supercharged side wind and break off into the engine.
__________________
Was also wondering about the tune. I want to get a dyno tune, and a place a few miles from me will do it. Do you think I could drive my car to the place staying with my current tune? Or do I need to contact doug for an update to drive my car about 4 miles?
isn't it true that the 2009 has built in non removable CMCV? that you need to buy smooth shafts that replace the butterflies. think i saw them for $80 somewhere.
The economy ones are good enough, and its best to get a retune for the plates however if you're just going to put them on and go straight to the dyno it's not needed but you will get a CEL.
__________________
FRPP Handling Pack, 95mm CAI, GT-500 throttlebody, FRPP CMCV delete plates, FRPP X pipe, JBA axle backs, Moto Blue UD Pulleys, PowerSurgePerformance 93 octane tune. Ford Racing Parts Dealer!! SpartaPerformance.com 13.05 @ 107.44mph.
For your info, 2009-2010 can use Steeda Part # 555-3148 "Charge Motion Delete Plugs"
for about $59.95 and takes same 3 hours labor to install..
