Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion > 4.6L V8 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-26-2009, 03:16 PM   #21
els35
els35's Avatar
Vehicle: 2009 GT/CS
I had the same question before, and they told me if I want a shiny thing under the hood go for it, other than that they are useless for bolt on MODS.. Save your money for other MODS.
els35 is offline   Reply With Quote
Old 10-01-2009, 04:47 PM   #22
Daniel60
2005 Ford Mustang
Daniel60's Avatar
Vehicle: 2005 Mustang GT
Quote:
Originally Posted by VN4308 View Post
I'm thinking 5 to 10 more horsepower is not worth the extra worries of electrical drain and less flow from the water pump on a DD....reading many different posts kind of help make up my mind....now if this was not a DD then Steeda UDP would be the way to go.....its seems some have no problems and some due...my luck I would fall into the some due catagory
that's your choice and that's unfortunate being that it's one of the most affordable mods that you can buy. I have had mine about four years and had no problem what so ever accept a little whinning noise at first on the belt but did notice a noticeable about of power increase. I paid 70 dollars to have them installed. they cost me then 200 dollars and a course I went with Steeda. Also know that a electric water pump will give you about 2 more horsepower at the most. Good luck with your decision.:icon_rally
__________________
"I love Global Warming"
Daniel60 is offline   Reply With Quote
Old 10-21-2009, 04:14 AM   #23
Vankor
Vankor's Avatar
Vehicle: 2005, Mustang, GT
I just got one of these pulleys and it will be installed in the next week. I had read on some of the older Mustang threads (late 80's bodystyle) that they seemed to mostly have problems with it, but I figure the electrical system is 20 years newer for my '05. So for the S197 models haven't experienced any issues with the Steeda UDP, so I'm trusting mine will be fine. I'm having it put on at the same time as my JBA headers and midpipe so I won't notice a difference from just the UDP. I'm just trying to minimize my trips to the shop :P
__________________
2005 GT, Mineral Grey, Steeda CAI & Brenspeed tune, Flowmaster Mufflers.
Vankor is offline   Reply With Quote
Old 10-21-2009, 04:38 AM   #24
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Vehicle: 2006 Ford Mustang GT
Quote:
Originally Posted by Alopez0630 View Post
Hey guys i have a quick question. What do you guys think about the steeda throttle body spacer for 05-09 mustang gts. Do you think its worth the buy
not worth it....
Quote:
agreed....useless
UDP's- get them an they will power everything on the car just fine.
Nuke and others....Electric H20 pump IMO is NOT worth it....you want a cooler engine .....get a different thermostat!!! (I have 160 deg from Whipple) the H20 pump we have now is more then enough esp for N/A cars.
Oh and that pump on a car with FI is a setup for disaster...as SteedaGus stated...when it fails temps rise quickly...then detonation....and BOOM...motor is toast!
__________________
2006 Mustang GT with Cervinis Kit
Whipple Crew member
H.O. S/C 465 RWHP and 440RWTQ
First online article about my car! check it out!
http://www.examiner.com/examiner/x-8811-Detroit-Sports-Car-Examiner~y2009m5d30-Jason-McGuires-2006-Mustang-GT
http://www.cardomain.com/ride/3342086
www.mocsem.com
mygt500 is offline   Reply With Quote
Old 10-21-2009, 10:12 AM   #25
Riptide
Riptide's Avatar
Vehicle: 2006 GT
Aren't UDPs worthless with a supercharger? I've always read around here that you don't bother getting UDPs if you get a blower.
__________________
2006 GT, Manual
JLT2 w/91 Tune
FRPP 4.10, Steeda LCA
MAC Boomtubes
Goodyear 255/45/18, 285/40/18
Riptide is offline   Reply With Quote
Old 10-21-2009, 03:33 PM   #26
Casey4s
Vehicle: '05 Mustang GT
Quote:
I would think an undedrive crank pulley with a blower would just make the blower spin slower, not a good idea if you are trying to make more power.
Casey4s is offline   Reply With Quote
Old 10-21-2009, 06:02 PM   #27
DLZ314
2005 Ford Mustang
DLZ314's Avatar
Vehicle: 2005 Ford Mustang GT
I've had my UDP for two Las Vegas summers in my DD 05GT and had no problems whatsoever. I run the A/C a lot. No real SOTP feel, but I did notice she's more rev happy with a slight increase in MPG. The install is simple and the UDP are worth it...
__________________
Suspension: Eibach Pro-Kit & Sway Bars, Tokico D-specs, Steeda Pan-Hard, Strut-Tower & G-Trac, BMR LCA
Brakes: Baer DecelaRotors, Hawk HPS, Goodridge Steel Braids
Engine: Steeda CAI & UDP, BrenSpeed 87 tune, Bassani BX & Catted-X
Misc: MGW STS
DLZ314 is offline   Reply With Quote
Old 10-21-2009, 08:51 PM   #28
mygt500
mygt500's Avatar
yes they are unless you have a Whipple and the Steeda belt drive....thats the only exception
Quote:
makes sense if your running one belt for the S/C and the accessories
not the case with this belt drive.....I was just throwing that out there but it is possible with the system I mentioned by Steeda.
__________________
Whipple Crew member
www.mocsem.com
Old 10-21-2009, 09:15 PM   #29
SirKnightTG
2006 Ford Mustang
SirKnightTG's Avatar
Vehicle: 2006 Mustang GT Premium Auto - Vista Blue
In some cases it's done to lower the boost intentionally. It's a popular thing to do with the Roush TVS unit since it seems the biggest pulley for it makes more boost than you would want on a stock block. So you'll drop a few psi by using a UDP putting you into the "safe zone."
__________________
Boomtube crew
TCI StreetFighter crew
Kooks crew
FRPP Hot Rod cams coming soon to a Thanksgiving near you...
camthumpinstang is a scammer!
SirKnightTG is offline   Reply With Quote
Old 10-21-2009, 09:20 PM   #30
SirKnightTG
2006 Ford Mustang
Because of this thread I'm starting to think differently about the eH2O and UDP.
If I can find a UDP at a good price I may just slap one on. Perhaps I can find someone selling a Steeda UDP they're taking off due to the install of a supercharger.
__________________
Boomtube crew
Kooks crew
2010, dyno, failure, gt, installation, mustang, problems, pulley, pulleys, steeda, test, udp, underdrive, void, warranty
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
