Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion > 4.6L V8 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-18-2009, 11:43 PM   #1
SVTERMINAT0R
Vehicle: 2005 FORD MUSTANG GT
Default gt500 dual fuel pump or boost a pump ?
my 05 gt currently has saleen supercharged stock pulley hto colder spark plugs 39 lb injectors saleen intake with k%n air filter
I WANNA UPGRADE TO 2.8 PULLEY BOOST A PUMP AND TUNE THE CAR HOW MUCH HP U THINK I GET OUT OF THIS PLS REPLY THANK YOU ALL
SVTERMINAT0R is offline   Reply With Quote
Old 09-19-2009, 10:10 AM   #2
RedFire281
With anything smaller than a 3.2 pulley I would recommend that you install GT500 pumps.
__________________
06 GT Redfire Manual. Saleen SC. Custom Diablo tune by Adam @ ST Motorsports, San Bernardino, CA.
RedFire281 is offline   Reply With Quote
Old 09-19-2009, 11:17 AM   #3
hammeron
hammeron's Avatar
Vehicle: 2006 GT
not sure how much HP, but it might
be a little over 500.
good luck and have fun
hammeron is offline   Reply With Quote
Old 09-19-2009, 02:57 PM   #4
Stkjock
Street Strip Sheriff
2006 Ford Mustang
Stkjock's Avatar
Vehicle: 2006 Mustang GT
if your not upgrading the injector get the GT500 pumps IMO, w/ the GT500 pump set up the 39s can flow like 48s with a proper tune
__________________
Tngstn 06GT-5 spd -Vortech HO S/C-Tuned by Realspeed Auto
You can never have too much power, just not enough traction.
11.867 @ 119.35
Stkjock is offline   Reply With Quote
Old 09-19-2009, 03:13 PM   #5
Stkjock
2006 Ford Mustang
Stkjock's Avatar
opps - dbl
__________________
11.867 @ 119.35
Old 09-19-2009, 07:37 PM   #6
SVTERMINAT0R
there is a almost $500 gap between gt500 pump and boost a pump i could use that 500 for tuning ? i wanna run only 12 psi im not sure boost a pump can support that !!!! what you think and thank you all for info .........
Old 10-20-2009, 03:26 AM   #7
nineinchnail1024
GT500 pumps. Instead of stressing a single pump, you'll be running dual pumps at a comfortable load. Also sets you up for future mods quite nicely.
__________________
Whipple Crew-10psi-Spec II-BMR LCAs-BMR sway bar delete-Spydershaft-M/T 26x11.5x17-Hurst-Prothane Mounts-PMP Line locks-Flows-Thump_rrr-Moroso separator-11.39@119mph
Daily Driver-2010 Prius-52.3mpg since new
Beater-1995 F150 XL-302 5spd
nineinchnail1024 is offline   Reply With Quote
Old 10-20-2009, 03:37 AM   #8
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Vehicle: 2006 Ford Mustang GT
Quote:
Dont skimp on the fuel system ......get the GT500 dual pumps....you can be maxing out your stock pump anyway with the BAP so get the GT500 pumps and the duty cycle will decrease (thats a good thing)
__________________
2006 Mustang GT with Cervinis Kit
Whipple Crew member
H.O. S/C 465 RWHP and 440RWTQ
First online article about my car! check it out!
http://www.examiner.com/examiner/x-8811-Detroit-Sports-Car-Examiner~y2009m5d30-Jason-McGuires-2006-Mustang-GT
http://www.cardomain.com/ride/3342086
www.mocsem.com
mygt500 is offline   Reply With Quote
Old 10-20-2009, 01:26 PM   #9
forensicsteve
Don't play around with the fuel supply...having just enough is not enough
__________________
06GT 76mm turbo, 302 stroker
2008 race season
4r70w(sold), triple fuel pumps(sold), 4:10 gears, spool
10.0@136 mph, 1/4
rwhp: not a clue, only number interested in is ET
2009 race season
built motor rebuilt (after boooom), custom intake manifold, III heads III spr cams,
powerglide transmission done, 3:50 gears, fuel cell build started
rwhp: enough to go low 9s
forensicsteve is offline   Reply With Quote
Old 10-21-2009, 11:07 AM   #10
IWinULose
2007 Ford Mustang
IWinULose's Avatar
Vehicle: 2007 Saleen S281 SC
I wouldn't go more than 500rwhp without internal work, first and foremost. Secondly, if you're going past the 450 rwhp mark, why not just be safe and go with the dual fuel pumps. You'll also need injectors. The blue 39s will be topped out about the same time as the fuel pump. When it comes to fuel, I would much rather be running a comfortable setup than be running everything at their maximum operating capacity. Finally, a 3.2 pulley will get you in the range of needing far more work than you have done, so I don't see the point in the 2.8.
__________________
Pitch Black 2007 Saleen S281SC #62
Saleen SuperShaker, JBA LTs and O/R H
FRPP Hot Rod Cams, Dual GT500 Fuel Pumps
MoSaleen Idler, 60lb Injectors, HT0 Plugs
3.4" Pulley, X3 tuned by PAS, 500+ RWHP
IWinULose is offline   Reply With Quote
2005, 2008, boost, dual, ford, fuel, gt, gt500, install, mustang, pump, pumps, set, setup, vortech
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
