Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion > 4.6L V8 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-22-2009, 08:16 PM   #31
JDWalton
Vehicle: 08 Mustang GT
So I think I got it fixed! The last items I replaced were the factory COPs with Weapon X ones, and a new set of plugs, properly gapped this time. I never gapped the ones that came with the kit from breenspeed (HT-0s) cause I was told they come at proper spec, but when I asked this time was told they should be set at .032 to .035 max. However out of the box there much closer to .04 So I got that worked out figured I would upload the pics of the old ones, these are with 5k miles on them:
__________________
My cars pics, vids and mods
To Lazy to update pic again right now:
WeaponX COPs, BBK 62MM Throttle Body, Stephs Catch Can, Spec Stage 3 clutch, 4.10 Gears, 18X9 up front, 18X10 in the rear, Eagle F1 Supercars
In Route: CDC Classic Chin - C/S Style, 1/4 Louvers
JDWalton is offline   Reply With Quote
Old 10-26-2009, 03:26 PM   #32
Derf00
Glad to hear you got it fixed. I know how you feel about wanting to do it yourself. Trouble these days is the diagnostic equipment is hella expensive and even with the knowledge to use it like a performance shop, you could still end up not finding the problem. The disturbing thing is no codes which leaves you scratching your head.
Those plugs looks pretty soaked for just 5K miles. I have a stock 08 S197 GT and when I replaced the two piecers with Champion one piecers at 12K miles they were clean as a whistle. I can't tell from the pick, but have you installed an oil-catch can? I'm thinking you're taking in oil from your PCV valve.
Slightly off-topic here but my wife's 06 escape just started exhibiting a similar thing to your car. I'm looking at the COPS and Plugs first. Only thing that really sucks about her truck is that three of the COPS and plugs are buried under the intake manifold so I have to remove it before I have access to either of them.
I'll end up running a primary and secondary resistance check on all six COPs to see if I find the bad COP (if that's the issue). Fuel injector is also a possibility. I'm hoping it's that easy. I've read up and the Crank Sensor can cause a misfire too.
Derf00 is offline   Reply With Quote
Old 10-26-2009, 10:43 PM   #33
GT Bob
Vehicle: 2007 GT
Get a catchcan on that thing ASAP... Wow... thats pretty bad for 5K miles, even gapped at .4
__________________
"Vera" '07 GT, 3.55's, MGW Shifter, BBK Shorties, GTA's, Steeda UDP, ProFab CAI #6, Summit Racing COP's,FRPP LCA's, Edlebrock PHB,UCA and STB, Steeda PHB brace, GT500 18x9.5 285/40/18's
Hang up and Drive.
GT Bob is offline   Reply With Quote
Old 10-27-2009, 01:00 PM   #34
JDWalton
already got a can on it ;-) though that was only added about 500 miles ago, apperantly too late!
__________________
Old 10-28-2009, 09:43 AM   #35
Simon1
2006 Ford Mustang
Vehicle: 2006 Mustang GT
Quote:
Originally Posted by JDWalton View Post
Will DO! I know if I dont get it with the next round of stuff, I am beyond simply being a sensor and have either a bad tune or damaged a more serious part that needs to be replaced. Either one will get much more expensive quickly.
Quick question to anyone here, are the front and rear O2 sensors the same? I know they do not perform the same job but wondering if I can swap front with rear to see if I have a problem with one or the other.
I don't know about swapping front to back O2 sensors but I know you can go side to side. There is enough wire to move them and it only takes a few minutes.
Your O2s should only be damaged is you ran leaded fuel or ran extremely rich for a very long time.
__________________
Motor Built and tuned by ST Motorsports
470/490 91 octane 10 psi
530/550 100 octane 12 psi
11.7 @122 with 1.78 60'
I'm not a member of any "Crews"
Simon1 is offline   Reply With Quote
50, cruising, forum, forums, hookup, line, misses, motorsports, mustang, speed, st, supercharger, tps, tuning, vacuum, vortech
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
