Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion > 4.6L V8 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-28-2009, 07:48 PM   #1
JDWalton
Vehicle: 08 Mustang GT
Unhappy Engine breaking up, need some help
Hey all. so all of a sudden my engine starts doing some weired things, i noticed it when I was getting on the gas going onto the highway the other day, and now am able to generate it pretty much at will.
Most noticeably at anything over 3rd gear, if at 2800 to about 3800 rpm and at 1/2 to 3/4 throttle, I start getting violent popping and snapping from my exhaust and very horrible stutters in the power from the motor. Now say I just go for it full throttle from a launch, I can run all the way up over 100 with no issues what so ever, and every bit of power is there.
Now surprisingly, when I was at Ford today about the two bolts that hold the passenger side of my bumper to the fender being missing, I spoke with one of there service managers about this. Now he asked me about my intake, and noticed the supercharger.... and the long tube headers, but still made a appointment for me and said they would take a look (never mentioned anything about trying to charge or status of my warranty,) but with the questions he was asking me it felt like he was trying to feel me out to see if I knew what I was doing under the hood.
So anyway, it goes in Thursday. So far I have taken some electrical contact cleaner and sprayed down my mass air. I also ran it near out of gas and filled with some fresh 93. Neither helped. So far thinking I might be looking at a new mass air sensor, or maybe a TPS, but wanted to ask you guys your opinions also. If its one of those 2, I'm confident I can get Ford to cover it, but would start to run out of idea after that. Was thinking maybe O2 sensors, but those get expensive when I am throwing them at it just to see. Was also thinking injectors or plugs, but again, getting expensive for the injectors, and tedious for the plugs, and I would think either of those 2 options would cause problems in a much less isolated situation. Oh well, have at it guys, any ideas welcome at this point.
__________________
My cars pics, vids and mods
To Lazy to update pic again right now:
WeaponX COPs, BBK 62MM Throttle Body, Stephs Catch Can, Spec Stage 3 clutch, 4.10 Gears, 18X9 up front, 18X10 in the rear, Eagle F1 Supercars
In Route: CDC Classic Chin - C/S Style, 1/4 Louvers
JDWalton is offline   Reply With Quote
Old 09-28-2009, 08:52 PM   #2
Stkjock
Street Strip Sheriff
2006 Ford Mustang
Stkjock's Avatar
Vehicle: 2006 Mustang GT
never mind... missed the info in the post
__________________
Tngstn 06GT-5 spd -Vortech HO S/C-Tuned by Realspeed Auto
You can never have too much power, just not enough traction.
11.867 @ 119.35
Stkjock is offline   Reply With Quote
Old 09-28-2009, 09:01 PM   #3
Simon1
2006 Ford Mustang
If you have a tuner I would suggest a data log be sent to your tuner.
I have had tuning issues with my car and it sometimes happens all of the sudden. When I was going through my issues I thought I had a bad TPS and MAF etc etc. The tuner stated the MAF either works or it doesn't, not half way. He also stated he had never seen a TPS go bad on our cars.
Instead of buying parts, have them salvage them from other cars to see if it makes a difference. A TPS or a MAF can be changed in a matter of minutes.
Did you try reloading the tune or disconnecting the battery?
__________________
Motor Built and tuned by ST Motorsports
470/490 91 octane 10 psi
530/550 100 octane 12 psi
11.7 @122 with 1.78 60'
I'm not a member of any "Crews"
Simon1 is offline   Reply With Quote
Old 09-28-2009, 10:38 PM   #4
GT Bob
Vehicle: 2007 GT
Without datalogging and diagnostic equipment, its hard to say for sure, but you do give some good info. The fact that it doesn't do it when the car is in a WOT state says that it's something to do with closed loop fueling during transitory conditions on the throttle... which is just a fancy way of saying that when your cruising and give a bit ore gas. At a guess, it may be something as simple as a loose vacuum hose, or a loose conection on a sensor. Wait and see what they find...
__________________
"Vera" '07 GT, 3.55's, MGW Shifter, BBK Shorties, GTA's, Steeda UDP, ProFab CAI #6, Summit Racing COP's,FRPP LCA's, Edlebrock PHB,UCA and STB, Steeda PHB brace, GT500 18x9.5 285/40/18's
Hang up and Drive.
GT Bob is offline   Reply With Quote
Old 09-28-2009, 11:09 PM   #5
JDWalton
if it was vacuum releated, I shoudl also see the bouncing on my boost gauge right? cause it stays pretty smooth. but yeah, gonna wait and see, they said thell hook up there diagnostics tool and go for a drive to see what numbers there getting while they recreate the problem.
__________________
Old 09-29-2009, 11:40 AM   #6
Starfire
Vehicle: 2008 Mustang GT/CS
Not that it has any relation, but was wondering what power you are putting out?
__________________
Mods: Stage 2 Brenspeed Saleen Supercharger, 20" Konig Beyonds
JBA shorties, Magnaflow catted X, Mid Muffler, BMR LCA's
425RWHP/404TQ
Starfire is offline   Reply With Quote
Old 09-29-2009, 04:34 PM   #7
GT Bob
Vehicle: 2007 GT
It's possible that you would see something, but not nessacarily. Depends on the relation of the leak to the boost guages pickup.
__________________
Hang up and Drive.
Old 09-29-2009, 05:01 PM   #8
moosestang
Quote:
If it is a vacuum leak, then you should notice it at idle. I'd pull the plugs and have a look. The plugs are easy to check.
__________________
Boost or Buell, decisions, decisions.
whipple HO SC,FRPP springs, Pypes mid mufflers, hurst, 4.10's, J&M extreme joint lca's, adj. UCA, relo bracets, 1 piece DS, spec stg 2 clutch. Accel coils 12.52@117.6mph so far with a 2.01 60 ft time(pre shaft, coils, clutch).
Downshifting Crew Member
moosestang is offline   Reply With Quote
Old 09-29-2009, 05:24 PM   #9
graygt07
Vehicle: 07 ford mustang
when i floored or got deep in the throttle it felt like power was way down and the exhaust would pop. If i got on the gas but went slower into the power no problems. I changed the plugs and all was fixed. I was blowing out a plug when i floored it and the fuel was burning in the exhaust hince the poppong.
__________________
07 auto with brenspeed stage 3 saleen 420rwhp/405
1.82 60' 1/8 7.65@93 1/4 11.90@115.5 on stock tires no susp. mods YET
UPDATE: stage 4 with saleen supershaker 454hp/439tq NEW PERSONAL BEST may 1, 2009 cordova il. 11.25@121.65 with 60' 1.649 on hoosier drs and all else stock.
graygt07 is offline   Reply With Quote
Old 09-29-2009, 08:21 PM   #10
JDWalton
yeah, but i can still make WOT runs at full speed with no loss in power. It also idles and drives normal fine. It is just odd cause its at a specific RPM range and under a specific amount of throttle. Just gonna end up letting them run there diagnostics this Thursday, if they cant come up with something good, I'll pull plugs this weekend.
__________________
50, cruising, forum, forums, hookup, line, misses, motorsports, mustang, speed, st, supercharger, tps, tuning, vacuum, vortech
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
