Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion > 4.6L V8 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-01-2009, 06:29 PM   #1
Xeremeh
2008 Ford Mustang
Xeremeh's Avatar
Vehicle: 2008 Ford Mustang GT
Send a message via AIM to Xeremeh Send a message via Yahoo to Xeremeh
Default Exhaust CEL Code
Hey guys,
Awhile back my CEL started going off. I checked it with my XCal and saw:
P0430: catalyst system efficiency below threshold (b2)
After a little research around the net, I've seen everything from bad O2 sensor, to a bad tune, to a bad cat, to oil in the exhaust, to bad spark plugs. I installed headers and mid myself. Mid has cats. I put in my CAI and brenspeed tune at about the same time. So I'm wondering what I should do here. Are there any tests I can run to figure out exactly what the broken issue is without spending an arm and a leg?
Thanks!
__________________
2008 Black Mustang GT Coupe "Black Widow"
Go: Steeda CAI, Brenspeed Tune, FRPP Shorties, Magnaflow X, Borla Stingers
Show: Pioneer AVIC-FB700, Meter4It Chase Sequentials, GT500 Rear Spoiler, Blue Map Lights, Faded Caliper Paint
"Don't tell my mom I'm a Soldier. She thinks I play piano in a whorehouse."
Xeremeh is offline   Reply With Quote
Old 10-01-2009, 06:59 PM   #2
Nuke
2007 Ford Mustang
My Garage
Nuke's Avatar
Vehicle: 2007 GT
Send a message via AIM to Nuke Send a message via Yahoo to Nuke
I'd get advice from the Brenspeed tech guys before doing anything.
__________________
Rick
07 GT Prem: Alloy, MT, 3.55's, Steeda CAI w/Brenspeed tunes, FRPP Stingers, 275/40/18 Goodyear Eagle F1 A/S on SVT Cobras (OE GT500's), 14" shorty, Wheelskin side scoops & qtr window louvers, A-H rear window louvers, SHR honeycomb blackout panel, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
06 V6: Legend Lime, Pony Package, 14" shorty, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
Nuke is online now   Reply With Quote
Old 10-02-2009, 12:03 AM   #3
2007VistaBlueGT
2007VistaBlueGT's Avatar
Vehicle: 2007 Mustang GT
Quote:
+1 Most likely a tune issue.
__________________
FRPP Handling Pack, 95mm CAI, GT-500 throttlebody, FRPP CMCV delete plates, FRPP X pipe, JBA axle backs, Moto Blue UD Pulleys, PowerSurgePerformance 93 octane tune. Ford Racing Parts Dealer!! SpartaPerformance.com 13.05 @ 107.44mph.
2007VistaBlueGT is offline   Reply With Quote
Old 10-02-2009, 02:11 AM   #4
tx_zstang
tx_zstang's Avatar
Vehicle: 2005 Mustang V6
Jeremy, I see this code too on one of my cats, and then eventually over time, the other one posts it as well (0420 for passenger side, 0430 driver side). I can tell you what you need to do to get it inspected, if that becomes an issue.
I think you said you kept cats on the car with your LTs.
There's a little "special modification" I was going to do to prevent this from happening (sorry, I wont post it publicly). Some of us can't modify the tune to turn the rear O2 sensors off. But if you can, then turning off the rear sensors will prevent those codes from showing up.
For those of you able to read OBDII data, if you look at mode 6 pids 21 and 22, they contain the data and thresholds related to this issue. During each driving cycle, a count of O2 cycles outside of limits is counted, in relation to the front O2 signal. If the amplitude is too large, the 'counts' increase. Then over a few driving cylces, the accumuated counts exceed the threshold limit, and the CEL is shown for it.
If those mode 6 counts can be adjusted in the tune to raise the thresholds to some very high value, I would like to know that for future reference and so it can be changed in my next tune.
__________________
Mike - 2005 V6 Automatic, 300+ RWHP; 12.79 1/4
Vortech supercharger (SOLD); 180*T-stat; PLX Wideband O2, VEI digital gauges, SOS pillar pod; JBA 9MM wires; Mac LT headers, high flow cats; 8.8 w/3.73s, LPW girdle, alum driveshaft, 3000rpm TC; Steeda UCA, panhard bar, brace; CHE lca's & reloc brackets; Steeda Sport springs, Tokico DSpecs.
.. "Sally" is getting "balls" ...forged V8 swap in progress
tx_zstang is offline   Reply With Quote
Old 10-02-2009, 06:31 AM   #5
Xeremeh
2008 Ford Mustang
Xeremeh's Avatar
Mike,
I actually am running shorties on it, which is why I was abit confused because everything hooks up just fine and I haven't seen many problem with cats and shorties. I emailed brenspeed. I hope this is just a matter of fine-tuning the tune.
__________________
Old 10-02-2009, 09:33 AM   #6
rdsx18
2005 Ford Mustang
Vehicle: 2005 Mustang GT
Quote:
Originally Posted by Xeremeh View Post
Mike,
How long after the header/x-pipe install did this start happening?
__________________
2005 Redfire GT
rdsx18 is offline   Reply With Quote
Old 10-02-2009, 09:43 AM   #7
Xeremeh
2008 Ford Mustang
Xeremeh's Avatar
I did the header/xpipe install about 2 weeks before the tune. Then about a week after the tune, it started coming on.
__________________
Old 10-02-2009, 09:48 AM   #8
rdsx18
2005 Ford Mustang
Hmm, would high flow cats set off this code? Or maybe you need the 02 raisers that brenspeed sells? I'm not sure, but I am sure brenspeed can help you out. Awesome people over there.
__________________
2005 Redfire GT
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
