Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion > 4.6L V8 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-05-2009, 05:23 PM   #1
probinator
Default is it dead or what
So my battery had tons of corrosion and I cleaned it the next day car worked fine. Now its dead again. I jumped It and the low fuel message comes on. But there's pleanty of gas. If I jump it again and even drove it far enough to have a charge the battery still dead. What can it be
__________________
2007 Redfire GT with SCT2 W/ C&L CAI. ZEX Nitrous kit, O/R X Pipe, Delete Plates,Steeda UDP, 4:10's, Lowered, spohn Lca's, panhard bar, Sway bar delete, Hurst STS, Tint, MMR rear seat delete. Stock Exhaust, Shortie antenna. ALL GO NO SHOW.
probinator is offline   Reply With Quote
Old 10-05-2009, 06:10 PM   #2
Nuke
2007 Ford Mustang
My Garage
Nuke's Avatar
Vehicle: 2007 GT
Send a message via AIM to Nuke Send a message via Yahoo to Nuke
It's a bad battery... The MotorCrap batteries aren't the best. And, if you leave the Shaker system on with the ignition off it drains the battery even worse than the normal, parasitic drain. By "tons of corrosion" I assume you mean that white and blueish powdery stuff. If so, then the battery is trashed. Even after a jump, the alternator will have difficulty trying to maintain the proper voltage due to the battery's condition. This will cause all KINDS of electrical gremlins.
And even IF the battery was still ok and only needed a charge, you'd have to drive at highway speeds for about 4 hours or more to get a good charge on it.
__________________
Rick
07 GT Prem: Alloy, MT, 3.55's, Steeda CAI w/Brenspeed tunes, FRPP Stingers, 275/40/18 Goodyear Eagle F1 A/S on SVT Cobras (OE GT500's), 14" shorty, Wheelskin side scoops & qtr window louvers, A-H rear window louvers, SHR honeycomb blackout panel, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
06 V6: Legend Lime, Pony Package, 14" shorty, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
Nuke is online now   Reply With Quote
Old 10-05-2009, 07:58 PM   #3
dysan
I've read that if your battery dies, you actually need to hook it up to a charger and not try and rely on the alternator to re-charge the battery.
dysan is offline   Reply With Quote
Old 10-06-2009, 03:12 PM   #4
moosestang
Quote:
the alternators job is to keep the battery charged, not to recharge a dead battery. If you kill your battery by leaving the lights on, then you should trickle charge it overnight.
__________________
Boost or Buell, decisions, decisions.
whipple HO SC,FRPP springs, Pypes mid mufflers, hurst, 4.10's, J&M extreme joint lca's, adj. UCA, relo bracets, 1 piece DS, spec stg 2 clutch. Accel coils 12.52@117.6mph so far with a 2.01 60 ft time(pre shaft, coils, clutch).
Downshifting Crew Member
moosestang is offline   Reply With Quote
Old 10-06-2009, 04:51 PM   #5
157db
Got Troy'd
157db's Avatar
Vehicle: 2007 Pony Package
wHATS THE VOLTAGE DROP INBETWEEN THE TERMINALS AND THE POSTS DURING CRANKING?
Fricken caps lock
__________________
NON PUMKIN JACKER
Quote:
Originally Posted by Boozshey View Post
Oh yeah, I forgot Norm was God on here.
Give me a break!!!
Quote:
Originally Posted by Norm Peterson View Post
<rises to the bait>
. . . Definitely not God.
Norm
157db is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
