Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion > 4.6L V8 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-17-2009, 04:39 PM   #1
sweetlou69
Default master/slave cylinder
I had a clutch related issue a few weeks back. Car wont go into gear when the clutch is pushed in. I can drive it via powershifting. I had a friend/mechanic look at it and he said its most likely the master or slave cylinder. My question is should i replace just the cylinders or while im at it should i mind as well go clutch/flywheel as well. Also is there any other parts i would need that would be causing this issue. ??
__________________
05 GT, 4.10s, JLT CAI, Brenspeed 93 Tune, Roush Axleback, Pypes O/R H,Steeda ultra lites, Tokico D-specs, Steeda adj PHB, Steeda Adj LCAS, Steeda LCA relocations brackets, Roush Body kit, Seibon 4' CF Induction hood, 20" Chrome Saleen style wheels
sweetlou69 is offline   Reply With Quote
Old 10-17-2009, 05:55 PM   #2
hammeron
hammeron's Avatar
Vehicle: 2006 GT
yes there are a few parts you could replace just
for fun, but why buy them now before we know
what the problem is.
odds favor the master cylinder being fine, so that
leaves the slave cylinder. to get to the slave
cylinder, the transmission has to be lowered.
you can get a new slave cylinder from rockauto.com
for around $100, or you can buy direct from
ford for a little more.
hammeron is offline   Reply With Quote
Old 10-17-2009, 06:05 PM   #3
sweetlou69
yes true, but i figured if the transmission is being dropped, mind as well do a clutch while the work is being done.
__________________
Old 10-17-2009, 09:41 PM   #4
BruceH
2008 Ford Mustang
BruceH's Avatar
Vehicle: 2008 Mustang GT/CS
Quote:
A stock clutch and pressure plate isn't too expensive, the flywheel can be resurfaced for about $40, here's a link to someone selling a new stock set up for $180. http://stangnation.com/index.php?topic=6660.0 If it was me I'd just have it done now since all clutches eventually need replacement and you are already paying the labor.
__________________
2008 GT/CS 5 Speed
Control Arms, Prothane MM's
Aluminum DS, McLeod RST/Fidanza FW
FRPP Ceramic Shorties
FRPP Whipple HO
Built Motor
Whipple Crew
BruceH is offline   Reply With Quote
Old 10-17-2009, 11:09 PM   #5
hammeron
hammeron's Avatar
Vehicle: 2006 GT
the clutch disk is definitely a might
as well do item. after the disk though,
it gets harder to say might as well do
this, or might as well do that.
i'd like you to replace everything in there,
but i also don't want you to spend the
extra money, if it might be a hardship.
05, 2005, 2006, 2007, 6th, clutch, cylinder, gt, hydraulic, located, mustang, replacing, slave, transmission, v6
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
