Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > 4.6L V8 Specific General Discussion > 4.6L V8 Technical Discussions
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-08-2009, 09:37 PM   #1
SCsaleen2006
Vehicle: 2006 saleen mustang
Default Upgrade block for s/c saleen mustang
Ok so my 06 s281 decided to blow a hole about the size of a quarter through my block. I dont think the internals could handle the 8psi of boost the company tuned it with. I am wondering if i find a block, forged internals and maybe going .20 over on the size of the pistons or even stroking it would be possible? I am hoping my heads are ok. If they are i want to keep them. Im just wondering what upgraded block and internals would fit my heads and supercharger. Id like to have around 600 hp and it not blow up again.
SCsaleen2006 is offline   Reply With Quote
Old 11-08-2009, 09:55 PM   #2
BruceH
2008 Ford Mustang
BruceH's Avatar
Vehicle: 2008 Mustang GT/CS
Here's one http://www.fordracingparts.com/parts...KeyField=10374 call Tousley Ford in MN for a good price.
You could also contact Chris Haney http://www.haneymotorsport.com/4.6L%...r%20Series.htm
He's one of the site sponsors and gives valuable input from time to time.
__________________
2008 GT/CS 5 Speed
Control Arms, Prothane MM's
Aluminum DS, McLeod RST/Fidanza FW
FRPP Ceramic Shorties
FRPP Whipple HO
Motor build underway
Whipple Crew
BruceH is online now   Reply With Quote
Old 11-08-2009, 10:01 PM   #3
SCsaleen2006
thanks ill check that out
Old 11-08-2009, 10:13 PM   #4
SCsaleen2006
Default Stroker kit on a saleen?
What if i went with the 5.0L Demon stroker modular 3v? what all would i have to change on my saleen then? Would the supercharger still work on it even?
Old 11-09-2009, 12:53 AM   #5
Simon1
2006 Ford Mustang
Vehicle: 2006 Mustang GT
If it'sa modular 3v you will be fine.
A built short block from Livernois would probably be my choice if my motor blew again.
Whoever does the assembly, make sure they have prior knowledge of these motors. When they blow they usually take other things with them. I had to replace all my valves/springs, cam phasers and intake manifold. Your intake manifold should be fine since it's part of the SC, but prior to placing it back on the motor I would have the unit sent back to Saleen or whoever can do port work on it to get a little extra and make sure no pieces flew up into the SC.
I guy bought a used SC (Saleen) from another guy in Fresno. He put the SC on and some pieces from the other guys motor fell out on start up and broke the motor.
Do it right the first time, talk with a hsop that has done exactly what your doing and enjoy the finished product.
__________________
Motor Built and tuned by ST Motorsports
470/490 91 octane 10 psi
530/550 100 octane 12 psi
11.7 @122 with 1.78 60'
I'm not a member of any "Crews"
Simon1 is offline   Reply With Quote
Old 11-11-2009, 01:57 PM   #6
Scord
Scord's Avatar
Vehicle: 2007 Mustang GT
+1 to above, make sure that supercharger is all good.
__________________
My Car - 2007 Alloy GT Mustang Coupe Automatic.
Steeda CAI, UDP//SCT Xcal II //Magnaflow 2.5" duel Cat-back//Pypes Off Road H-pipe//FRPP 4.10 Gears.
Shelby 14" Break kit//Vogtland Springs //J&M Billet LCA, UCA, double adj Panhard Bar, Camber Plate.
Scord is offline   Reply With Quote
Old 11-14-2009, 04:42 PM   #7
GT Bob
Vehicle: 2007 GT
What part of PA you in? If you on the Eastern end of the state, it may be worth your time to check into JDm engineering in Jersey.
As a side note, every time I look at a shortblock ad, I can't help but wonder why not get the strokers? I've yet to see one thats more than like 3 or 4 hundred more than a stock cube and any class rules aside, more Cubic Inches are never a bad thing..
Anyone remember a while back one guy had picked up an Sean Hyland 6 liter block? Can't remember if it was a short block or a bare block. Wonder what ever happened to it?
__________________
"Vera" '07 GT, 3.55's, MGW Shifter, BBK Shorties, GTA's, Steeda UDP, ProFab CAI #6, Summit Racing COP's,FRPP LCA's, Edlebrock PHB,UCA and STB, Steeda PHB brace, GT500 18x9.5 285/40/18's
Hang up and Drive.
GT Bob is offline   Reply With Quote
Old 11-14-2009, 05:16 PM   #8
IWinULose
2007 Ford Mustang
IWinULose's Avatar
Vehicle: 2007 Saleen S281 SC
+1 on JDM.
Theoretically, the stroker motors are not as reliable as your run of the mill stock CI motor. The stock 4.6L motor has a 90.2mm bore and a 90mm stroke, thus making the motor almost square. Hard to reason against ol fashioned geometry. With that said, it all depends on what you want out of your engine.
__________________
Pitch Black 2007 Saleen S281SC #62
Saleen SuperShaker, JBA LTs and O/R H
FRPP Hot Rod Cams, Dual GT500 Fuel Pumps
MoSaleen Idler, 60lb Injectors, HT0 Plugs
3.4" Pulley, X3 tuned by PAS, 500+ RWHP
IWinULose is offline   Reply With Quote
Old 11-16-2009, 05:24 PM   #9
SCsaleen2006
Default Block and heads?
I live near pittsburgh..what kinda block would you recommend if im shooting for around 600 hp..if my heads are fine im trying to reuse them with it..im not sure if there gt40 heads or what..i just dont want anything to f up again lol
Old 11-16-2009, 11:12 PM   #10
SirKnightTG
2006 Ford Mustang
SirKnightTG's Avatar
Vehicle: 2006 Mustang GT Premium Auto - Vista Blue
Quote:
Why is that?
__________________
Boomtube crew
TCI StreetFighter crew
Kooks crew
FRPP Hot Rod cams coming soon to a Thanksgiving near you...
camthumpinstang is a scammer!
SirKnightTG is online now   Reply With Quote
2006, mustang, s281, saleen, supercharged, upgrades
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
